new turbo.. ignition
Old May 13, 2005 | 08:02 AM
pv2dickman's Avatar
Default new turbo.. ignition
i am putting a turbo on my bone stock b18c1.. t04e 57 trim.. runnin it 7 psi.. not boostin till i get better management and engine work obviously
anyway
when i put the kit on is there anything i have to do to the ignition.. like retard it or something.. or is 7psi not going to do much.. and what is a good recomendation on spark plugs..
Old May 13, 2005 | 12:25 PM
Da K00l Aid Mayun's Avatar
Default Re: new turbo.. ignition (pv2dickman)
Spark Plugs = NGK's
Old May 13, 2005 | 12:47 PM
Maveric's Avatar
ngk plugs 1-2 steps colder
Old May 13, 2005 | 02:34 PM
dustin's Avatar
BKR7E, gap to about .032"
are you using am FMU for fuel? if so, retard timing to about 14deg at idle.
Old May 13, 2005 | 05:51 PM
tommy1's Avatar
you will probably end up having to retard your timing becuase I have a setup similar to that, but my turbo is the 60 trim. I am using the NGK 1 step colder plugs and they are working good.
MBlake55
Feb 27, 2006 06:16 AM
TOP*SECRET
Apr 8, 2005 07:05 PM
eg2turbo
Jan 30, 2003 07:38 PM
1sick4door
Feb 14, 2002 09:39 PM
