new track times....evaluate please
Old Jan 17, 2003 | 10:29 PM
TurbothisLS's Avatar
Default new track times....evaluate please
Out of 9 passes tonight down at Seguine with ClubRSX:
4 of the best
Top ET's with Nitto 555R's:
60 FT - 2.3869
1/8 ET - 9.3198
1/8 MPH - 81.16
1/4 ET - 14.2138
1/4 MPH - 101.39
60 FT - 2.3576
1/8 ET - 9.3338
1/8 MPH - 81.30
1/4 ET - 14.2169
1/4 MPH - 101.53
Top Trap:
60 FT - 2.5288
1/8 ET - 9.4677
1/8 MPH - 81.49
1/4 ET - 14.3041
1/4 MPH - 104.26
why can't i break 13's????
please help me
Old Jan 17, 2003 | 10:40 PM
Flamenco-T's Avatar
Default Re: new track times....evaluate please (TurbothisLS)
get a 3" exhaust, free up some more power out of it, get your trap speed to 105ish.
practice on your 555r, get you 60 to 2.1 or lower, you'll break 13's
stan
Old Jan 17, 2003 | 10:43 PM
paulzy's Avatar
Default Re: new track times....evaluate please (Flamenco-T)
reason number 1:2.3, 2.3, 2.5 60 ft. times
Old Jan 17, 2003 | 10:46 PM
Mr.DC2TurBo's Avatar
Default Re: new track times....evaluate please (1320development)
True, those are very similar numbers for automatic turbo b18b but at 7 to 9psi tho. I believe there's somthing wrong with your launch or maybe those tires aren't cutting it. 10psi should get you in the low 13s.
[Modified by LS-T2001, 1:48 AM 1/18/2003]
Old Jan 17, 2003 | 11:15 PM
Flamenco-T's Avatar
Default Re: new track times....evaluate please (LS-T2001)
he's on stock exhaust, thus the reason I recommended a 3" exhaust to free up hp
Old Jan 17, 2003 | 11:17 PM
wow, didn't know stock exhaust can do that much damage, lol.
Old Jan 18, 2003 | 09:35 AM
i'm thinkin i have to fix my 60ft before i head for a larger exhaust
if i gain hp, i'll get more traction issues, rather than fix the ones i already have
where are u launching at?
i'm getting a lot of spin. the tires don't stick in first and i only get the top 2k rpms in 2nd.
Old Jan 18, 2003 | 10:02 AM
Joseph Davis's Avatar
What rpm are you launching at?
My experience with street tires at the track is they spin a lot compared to regular pavement. All that rubber embedded in the asphalt isn't helping you unless you have slicks. Try to modulate the throttle on 1-2 shifts with street tires.
Old Jan 18, 2003 | 10:06 AM
DIRep972's Avatar
Smarter than you
your mph is right where it should be. just gotta practice those luanches.
are u cleaning the tires off in the water and doing a big burnout? the nitto's really need to smoke to get heated up. if u heat em up enough they will hook bad ***. u should be luanching around 4k if the tires are heated up enough.
Old Jan 18, 2003 | 10:23 AM
ekb18c's Avatar
Default Re: new track times....evaluate please (hopefor12's)
Yup, 104mph is good for 13.4-13.6, somewhere in that range. Get your 60ft down to 2.0 or lower and you're there.
Old Jan 18, 2003 | 12:36 PM
VTEC-DA's Avatar
Default Re: new track times....evaluate please (ekb18c)
Alot of people disagree with me on this, but I found that it works for me. When you shift, dont do it as fast as you can, let the RPM's drop and then shift right before it drops out of your powerband. I found that this helps alot with traction in second. I dont mean takes 5 seconds to shift into 2nd, but wait half a second or so after you would normally shift.
Old Jan 18, 2003 | 04:36 PM
Default Re: new track times....evaluate please (VTEC-DA)
nitto 555r
[Modified by TurbothisLS, 1:36 AM 1/19/2003]
Old Jan 18, 2003 | 05:22 PM
98civicEX's Avatar
it's your 60ft, like everyone else said, your mph is there like colin said. i think once you can hit a 2.1 or better, then welcome to the 13 second club. just wondering what your tire pressure was at?
Old Jan 18, 2003 | 05:33 PM
tony1's Avatar
Default Re: new track times....evaluate please (98civicEX)
remember, a tenth in your 60ft. is usually 2-3 tenths in the quarter!
Old Jan 18, 2003 | 05:48 PM
stick's Avatar
Default Re: new track times....evaluate please (tony1)
thats what i was gonna say. aim for 1.8 or 1.9 60 ft.
shift at redline in each gear. u definitely have a low 13 sec LS-T
Old Jan 18, 2003 | 07:13 PM
sushibug's Avatar
kick me if im wrong, but the only reason his trap speed was that high was because his launch wasnt up to par. of course your mph is higher when you spin the tires more.
Old Jan 18, 2003 | 09:35 PM
Default Re: new track times....evaluate please (sushibug)
that's what i heard too
but i still feel that this car is 13 seconds already, just not there because of traction issues.
anyone have advice on fixing traction issues? better tires, where to launch at?
Old Jan 18, 2003 | 09:38 PM
Steno's Avatar
Get some Jimfab bars. Contact Arturbo or ninesecrx about them.
Paul.
Old Jan 18, 2003 | 10:48 PM
RyanAutry's Avatar
225/50R-15, BFGoodrich g-Force T/A Drag Radial
It's more or less a 24" slick.
Overall Diam. 23.9" x 7.6 x 15.0
Tread Width 7.6"
23.9 x 7.6 x 15.0
My friend cuts low 1.8 60ft's on these with his LS/Turbo Hatch *LSD*
I ripped a 2.08 w/o LSD
Best street tire on the market.
http://www.diamondstarmotorsport.com/wheeltire.shtml
These guys cut 1.5's with these tires.
Old Jan 18, 2003 | 10:54 PM
LS-hatch's Avatar
Default Re: new track times....evaluate please (RyanAutry)
Ive heard bad things about reliability on the BFG's. How long would they last with only the occasional track visit?
Old Jan 18, 2003 | 11:03 PM
Default Re: new track times....evaluate please (LS-hatch)
so go with the nitto 555r's?
Old Jan 18, 2003 | 11:08 PM
RyanAutry's Avatar
I took mine to the track 12 times. Plus the occasional Sat night out . They lasted all summer for me... Then they were toast...
But I'll spend the $250 every summer for traction.
Winter time = Falken Azenis.
Old Jan 18, 2003 | 11:09 PM
RyanAutry's Avatar
555r's
g-force DR's
Old Jan 18, 2003 | 11:51 PM
BoM's Avatar
BoM
stan
i agree, it can spool your turbo up faster. then you'll really be quick.
Old Jan 19, 2003 | 01:35 AM
Jdm_Rice_Monster's Avatar
Default Re: new track times....evaluate please (BoM)
damn, where did you go run at. I cant wait to hit the track.
