need vacuum lines corrected
Old Nov 26, 2008 | 09:04 AM
killacam661's Avatar
Default need vacuum lines corrected
i need to get my lines hooked up correctly before i take it in to get it tuned.
im waiting on a vaccum manifold from GE so all the lines are "t"ed just temporarily...
but my main question is for the wastegate... there are two nipples and i don t know how they go.
also for the fmu...it doesnt way which one is the ilet and outlet.
Please help guys.
HAPPY THANKSGIVING ALL
Old Nov 26, 2008 | 09:32 AM
95jeremie's Avatar
i"m 90% that the bottom in the one that you will want to use
the top one just leave unpluged
Old Nov 26, 2008 | 06:41 PM
boostedcivicsir's Avatar
Mr. Badwrench
bottom port on the wastegate is boost reference. top is for boost controller.
in throught he side of the fmu, out throught the bottom.
stupid question? how are you getting it tuned? i mean with the fmu and all.
Old Nov 26, 2008 | 08:02 PM
SovXietday's Avatar
FMU and tuned aren't really supposed to be in the same sentence, but ok.
Old Nov 26, 2008 | 08:28 PM
i put the fmu on just to drive it to the tuner. im gunna be on s200.
and i dont see the sentence with im takeing it to the tunes with the fmu on. why there always gotta be smart asses? whatever holmes.
ttt who tunes hondata near the 661?
Old Nov 26, 2008 | 08:34 PM
Default is this correct?
http://cgi.ebay.com/ebaymotors/10-x-...Q5fAccessories
Old Nov 27, 2008 | 08:08 PM
ttt i think i have the fmu fuel lines backward.... someone helpppp
Old Nov 30, 2008 | 11:46 PM
AdamB18C1EK's Avatar
well you might want to try to use something other than windshield washer fluid hose for your fmu.....
Old Dec 1, 2008 | 06:21 AM
shortyz21's Avatar
yeah no kidding, that stuff will get so warm when it gets vac itll suck closed
Old Dec 1, 2008 | 07:26 AM
SOHC_MShue's Avatar
so you cant just lay out of the gas long enough to drive it to the tuner? A stock ecu and injectors would be sufficient to get the car there.
Old Dec 1, 2008 | 07:29 AM
HiProfile's Avatar
If you plan to drive to the tuner AND BOOST on it, just make sure you have your AAA card, or at least a friend with a tow truck. And a spare motor.
FMU's aren't always plug & play nor work well, which is why they haven't been a high-end Honda part since forever. You can drive w/o anything, as long as you stay out of boost. Either way if you boost w/o proper tuning, you're risking your whole motor.
You've waited this long for to get it turbocharged, why can't you wait a little longer?
Chewy Built !
Oct 14, 2007 09:14 AM
quicksol95
Sep 23, 2004 09:46 AM
b16 pwrd ek
Mar 25, 2003 12:05 PM
DC2R714
Mar 7, 2003 08:50 AM
1.8T_EG
Aug 27, 2002 07:09 AM
