Need suggestions, dyno pulls of 9-15lbs yield same power
Old Jul 11, 2004 | 12:22 PM
Pfieff's Avatar
Default Need suggestions, dyno pulls of 9-15lbs yield same power
Well, I went to the dyno yesterday hoping for the magic number of 300whp and came home very disappointed/frustrated. No matter what the boost was set to(9-15lbs), I would pull anywhere from 165-170whp. Fuel and timing curves were right on, compression test was 200 across the board. I am running a t3/to4e 50 trim .48 ar on a d16y7 and the turbo would spool and hit full boost at around 4200 rpm and hold steady til we let off but power would start to fall off after 5500rpm which it shouldn't do with a turbo of that size. We tried a run open DP to see if my cat was clogged up or something and that didn't do ****. My new motor had 700 miles on it once it got to the dyno and I was starting to think that the rings never got seated properly and were allowing blow by. Would the compression test yield lower #'s if my rings weren't seated? I thought it would, but I am going to try a leakdown test later today or tomorrow and see what comes up. Any ideas are greatly appreciated.
EDIT: heres the setup
d16y7
cp pistons/eagle rods
ARP's
ferrea valves/springs/retainers
maxrev manifold/DP
tial 35mm WG
rc550's
walbro 255
greddy type 31 FMIC
spec stage 3 6 puck clutch
ACT streetlite flywheel
Modified by Pfieffdog at 10:27 AM 7/13/2004
Old Jul 11, 2004 | 03:07 PM
Pfieff's Avatar
bump
Old Jul 11, 2004 | 04:59 PM
J337_UNIT's Avatar
Default Re: Need suggestions, dyno pulls of 9-15lbs yield same power (Pfieffdog)
if rings were not seated right then you would yeild poor compression results
dont feel bad bro.. i only made 196whp on 8 psi on my motor... yet it is VERY healthy... it makes no sense to me..
Old Jul 11, 2004 | 05:04 PM
ATS*Mark's Avatar
OG triple OG
Default Re: Need suggestions, dyno pulls of 9-15lbs yield same power (J337_UNIT)
thats really wierd . somthing else is comming into play here . maybe you just need better flow , what tb and im are you running? and p&p work?
Old Jul 11, 2004 | 05:07 PM
M.A.R.C.'s Avatar
Default Re: Need suggestions, dyno pulls of 9-15lbs yield same power (Hella_JDM)
that's weird. where's the boost gauge signal coming from? possibly u have a boost leak somewhere after that?
Old Jul 11, 2004 | 05:09 PM
J337_UNIT's Avatar
ya many factors go into play.. i never realized how sensitive forced induction is to humidity and outside air temp and air density. On a very cool day i feel like im making a ton more power then when it is hot as hell outside. Also it could be a problem with the dyno? settings are not calibrated properly perhaps? I know when i was on the dyno my car was having some serious heat soakage.. The first day i went i was making 227whp !!! then the next day i went back .. it was like 20 degrees hotter out.. i couldnt get over 200whp.
Old Jul 11, 2004 | 05:45 PM
ATS*Mark's Avatar
OG triple OG
hell ya , in the morning when it was real cold i could shift like a granny into second , then slowly go to wot and it would loose all kinds of traction . on the warmer days first would bearly break
Old Jul 11, 2004 | 10:16 PM
Pfieff's Avatar
Boost was being read from the boost gauge as well as the dyno and both were consistent with one another. The dyno is reading right because I went out on the road and did 2 back to back pulls at 10 and then 15lbs and it didn't feel any different(slow). Throttle body is a stock y8 TB and its a y8 IM. Another other suggestions?
Old Jul 11, 2004 | 10:17 PM
Pfieff's Avatar
Also, what would be causing a decent amount of smoke out the breather filter?
Old Jul 11, 2004 | 10:31 PM
J337_UNIT's Avatar
Default Re: (Pfieffdog)
\\<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Pfieffdog &raquo;</TD></TR><TR><TD CLASS="quote">Also, what would be causing a decent amount of smoke out the breather filter?</TD></TR></TABLE>
this smoke you are referring to is "blow by" smoke.. its essentially a sign that there is not enough crankcase ventialation process of the motor.
Old Jul 11, 2004 | 10:34 PM
user 996328629's Avatar
Default Re: (J337_UNIT)
Same thing with me, ive pretty much guranteed myself that my rings are shot in my pistons, i burn a **** load of oil, and no power past 5500...
Old Jul 12, 2004 | 03:46 AM
Pfieff's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by J337_UNIT &raquo;</TD></TR><TR><TD CLASS="quote">\\
this smoke you are referring to is "blow by" smoke.. its essentially a sign that there is not enough crankcase ventialation process of the motor.</TD></TR></TABLE>
And one would go about fixing this how?
Old Jul 12, 2004 | 04:11 AM
Chillinit's Avatar
And one would go about fixing this how?</TD></TR></TABLE>
you have to get a catch can....however the access crank case gases not being ventilated is not likely the cause of your lack off power at different boost levels.
I would suggest doing a compression test however you have already done that....so I'm not sure whats the cause.
good luck
Old Jul 12, 2004 | 05:28 AM
menkio's Avatar
Default Re: (Chillinit)
pistons/rings.. d16y7, 110 bucks. msg fjt.. get thoose 8.5:1 suzuki pistons, some cheapo hasting rings. problem solved and then some.
Old Jul 12, 2004 | 05:38 AM
Pfieff's Avatar
Default Re: (DewMota)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DewMota &raquo;</TD></TR><TR><TD CLASS="quote">pistons/rings.. d16y7, 110 bucks. msg fjt.. get thoose 8.5:1 suzuki pistons, some cheapo hasting rings. problem solved and then some. </TD></TR></TABLE>
I'm already running cp pistons/eagle rods
Old Jul 12, 2004 | 07:54 AM
Pfieff's Avatar
back up
Old Jul 12, 2004 | 08:36 AM
DIRep972's Avatar
Smarter than you
What does your fuel system consist of and what are you using to tune with?
Old Jul 12, 2004 | 08:49 AM
Pfieff's Avatar
Default Re: Need suggestions, dyno pulls of 9-15lbs yield same power (DIRep972)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DIRep972 &raquo;</TD></TR><TR><TD CLASS="quote">What does your fuel system consist of and what are you using to tune with?</TD></TR></TABLE>
Fuel system is rc550's, walbro 255lph fuel pump, and tuning was done with hondata s100b
Old Jul 12, 2004 | 08:52 AM
espanol's Avatar
here's the only things i could think of based on motors that have done the same thing:
1.turbo is trash
2.motor is trash
3.it's a single cam
Old Jul 12, 2004 | 08:55 AM
DIRep972's Avatar
Smarter than you
Fuel system is rc550's, walbro 255lph fuel pump, and tuning was done with hondata s100b</TD></TR></TABLE>
ok that looks good. does your engine have vtec? I was gonna ask if it is engaging?
Old Jul 12, 2004 | 09:02 AM
rioninja's Avatar
Sounds like you have a boost leak. If the leak is small enough, you will still build
boost. THe turbo just has to spin like hell to keep it up = falling out of its efficiency
range. WAAY out of its efficiency range.
At least i can only guess without seeing it in person, but thats the most likely thing.
Old Jul 12, 2004 | 10:18 AM
Pfieff's Avatar
ok that looks good. does your engine have vtec? I was gonna ask if it is engaging? </TD></TR></TABLE>
The d16y7 is a non vtec motor so vtec engagement wasn't a concern.
Old Jul 12, 2004 | 10:19 AM
Pfieff's Avatar
Default Re: Need suggestions, dyno pulls of 9-15lbs yield same power (rioninja)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rioninja &raquo;</TD></TR><TR><TD CLASS="quote">Sounds like you have a boost leak. If the leak is small enough, you will still build
At least i can only guess without seeing it in person, but thats the most likely thing.</TD></TR></TABLE>
This wouldn't show any power differences between 9 and 15lbs?
Old Jul 12, 2004 | 10:28 AM
allablur's Avatar
i am sure this seems like a weird question but is your crank KNIFE EDGED?
also what manifolds are u using? i.e. intake and turbo? and any head work?
Old Jul 12, 2004 | 11:24 AM
Pfieff's Avatar
Default Re: Need suggestions, dyno pulls of 9-15lbs yield same power (allablur)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by allablur &raquo;</TD></TR><TR><TD CLASS="quote">i am sure this seems like a weird question but is your crank KNIFE EDGED?
also what manifolds are u using? i.e. intake and turbo? and any head work?</TD></TR></TABLE>
Crank is not knife edged. IM manifold is from a y8 and the turbo manifold is a maxrev log manifold. Head is built with ferrea valves/springs/retainers and I'm using ARP head studs
