need some quick advice
ok i bought a turbo kit off a friend and its got the manifold, turbo, charge pipes, wastegate, bov. The thing is its off a d series and i have a b18, how much work will be involved in converting it to my b? i also have a b series turbo manifold, also what else will i need to get this bad boy running? thx
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wpgcivic »</TD></TR><TR><TD CLASS="quote">ok i bought a turbo kit off a friend and its got the manifold, turbo, charge pipes, wastegate, bov. The thing is its off a d series and i have a b18, how much work will be involved in converting it to my b? i also have a b series turbo manifold, also what else will i need to get this bad boy running? thx</TD></TR></TABLE>
You basically have all that you need. You mite have to shimmy the i/c piping couplings a lil because both manifolds might not set the compressor at the same location....By the way, are both the manifolds for the same size turbine and plus...do you have an intercooler?
yeha thats another thing, i need to get the adapter plate switched over i believe, and not too sure about what you mean about the turbine, im a n00b when it comes to turbo stuff
