Need some help with a GSR Integra
Old May 13, 2006 | 08:38 PM
SovXietday's Avatar
Default Need some help with a GSR Integra
Hey guys, need to inquire some brains for project I'm about to embark on. My friend owns a GSR (not sure what year, but it'd OBDII), and he's looking for boost. He wants to either go turbo or SC, now I know all that I need to know about the SC to help him out, but turbo and what kind of power he can expect is a different question. As my sig states, I own a supercharged D, and haven't really looked into Bseries engines, so I'm not 100% sure on all of this.
The car needs to be 100% streetable and as reliable as possible. I figure 250whp will be plenty if not too much, he can always upgrade later. Just quick questions.
1) What size turbo would be good for this kind of goal on a GSR?
2) Stock internals should be able to handle 250whp right?
3) Stock fuel pump can handle it, correct?
4) RC 440s big enough, or should he just get some 750s?
5) What OBDI ECU should he get, a P70?
Help would be great, I want to try and keep him from spending a ton of money on a "kit."
Old May 14, 2006 | 09:55 PM
qfast817's Avatar
Default Re: Need some help with a GSR Integra (SovXietday)
1 persion sc-61
2 yes they can
3 255 walbro pump
4 880's
5 p72
i made 250hp at 5 psi with a ineedhelp manifold
Old May 14, 2006 | 10:00 PM
hondahatchgsr's Avatar
1. The SC-61 is a pretty big turbo...my friend made 400 hp with that turbo setup in his gsr.
2. Agree
3. 255 for sure
4. Um you dont need that big of injectors...I have seen in real life 310's make 325 hp...on a GSR...if you want bigger then that how bout some 550's
5. P72 also...
Old May 15, 2006 | 02:51 AM
96 GSR-T's Avatar
Default Re: (hondahatchgsr)
1. SC61 is way overkill, will spool slow with that car - Just a basic 57 or 60 trim t3/t4
2.
3. Walbro 255
4. 440's or 550's
5. P72 - P61 will work fine, and have the knock sensor
Old May 15, 2006 | 06:46 AM
qfast817's Avatar
Default Re: (96 GSR-T)
yea i know sc-61 is over kill but it made 250hp and 178tq at 5psi, and lag wasnt that bad till 3200 rpm
Old May 15, 2006 | 09:06 AM
96 GSR-T's Avatar
Default Re: (qfast817)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by qfast817 &raquo;</TD></TR><TR><TD CLASS="quote">yea i know sc-61 is over kill but it made 250hp and 178tq at 5psi, and lag wasnt that bad till 3200 rpm </TD></TR></TABLE>
What SC61??? The smallest SC6152 has a Stg5 (T350) turbine wheel which I would love to see you spool it up under 4k..... especially with a stock bottom end.
Team Si by FCC
May 13, 2009 05:16 PM
wegotmorrison
Mar 4, 2009 09:25 AM
hondatuner020
Sep 14, 2008 07:30 PM
gsr x civic
Feb 16, 2007 01:04 PM
