Need quick help... AN Fuel line problem? leaking?
Old Aug 26, 2005 | 02:15 PM
N20civicB18's Avatar
Default Need quick help... AN Fuel line problem? leaking?
I bought a used fast-turbo.com fuel line (fuel filter to rail) off a fellow honda-tech'r with fuel rail and FPR. I installed everything today but the fitting are leaking. I cant find a picture of the line I have but...
this is not a fuel line but has a similier bend on the bottom of picture, left side fitting.
its not the blue piece that screews into the piece into the filter, its right after the bend the blue piece that screews onto the red piece that holds the line together. it is leaking from the top of the blue piece (where the blue aluminum line comes out of. how do I fix this? both of them are leaking, the 90? that comes off the filter and the 45? that goes to the rail. I need some quick input guys!
Thanks
Kyle
Old Aug 26, 2005 | 02:24 PM
Default Re: Need quick help... AN Fuel line problem? leaking? (N20civicB18)
damn i didnt realize i could be so good with paint
sorry if its a little big, i should of shrunk it more
Old Aug 26, 2005 | 03:02 PM
BoostedEG6's Avatar
well sounds to me like you need a new fitting.... but I could be wrong..... is everything tight?
Old Aug 26, 2005 | 03:05 PM
Default Re: Need quick help... AN Fuel line problem? leaking? (BoostedEG6)
yes everything is tight... how could the fitting go bad? how do I know if its bad?
Old Aug 26, 2005 | 09:37 PM
SFWD 1934's Avatar
That is a 120 degree swivel fitting. If in fact it is leaking from that place that you pointed to, then you will have to buy a new one. Are you positive that it is not leaking at the point where the sleeve (the red part of the fitting) mates up with the aluminum bend (the blue part of the fitting).
Jason
ODbuilt
Apr 26, 2014 12:50 PM
EK9r!der
18
Aug 23, 2012 09:57 PM
sk8shorty012
May 6, 2009 12:10 PM
Ubermensch
Sep 24, 2001 07:50 AM
