Need help with Zex kit
Old Jul 10, 2001 | 10:58 AM
97tegger's Avatar
Default Need help with Zex kit
Quick question for you guys.
I just bought a used Zex kit and was wondering what else you guys would recommend upgrading. I have a 97 non-vtec integra with the basic bolt ons and 45000 miles. I'm planning to run just the 55hp jet for now, but is it safe to spray 65 or even the 75hp jets safely? Do you guys recommend retarding the timing a couple degrees and I plan to get a FPR on the safe side, so how much extra fuel should I deliver? And what kind of plugs do you guys recommend?...1 step or 2 steps colder?
Also, if anyone has the instructions or the list of parts the kit is suppoesed to come with can you please email it to me at stchow76@hotmail.com or post a link to it.
TIA
Old Jul 10, 2001 | 11:10 AM
b18bturbo's Avatar
Default Re: Need help with Zex kit (97tegger)
get 1 step colder the b18b motor should be able to take a good amount of n75 shot will work if you setup the fuel pressure correctly.
Old Jul 10, 2001 | 11:52 AM
ITS BONE STOCK I SWEAR's Avatar
New User
Default Re: Need help with Zex kit (b18bturbo)
NO NO NO
dont do it i had a it in my 01 GSR Properly set up with basic bolt ons and it wore down my motor and my motor blew. I have 3 other friends that have also blown there motors on 75 I now have a 55 for the last 6 months and it has been fine. dont go any higher unless you get the nos kit and go direct port
Old Jul 10, 2001 | 11:57 AM
b18bturbo's Avatar
Default Re: Need help with Zex kit (slapmyfro)
I would have to disagree with you there If you fuel is setup properly the kit should be able to hold fine. bad tuning is what blows engines. Not enough fuel to match the increase in oxygen in the motor.
Old Jul 12, 2001 | 08:56 AM
TypeC's Avatar
also get the zex plugs from zex.com for $20 (set of 4). The normal plug will turn into glowplugs, causing detonation and the electrodes will break off. It happened to me and others, especially with a big shot. HTH, -C
Old Jul 12, 2001 | 10:06 AM
Big James's Avatar
New User
NO NO NO
Damn, what did you screw up? I ran a 75 shot on my Accord motor for quite a while with no problems. Ran a 75 shot on the Lude motor no problems. I got rid of the ZEX because I wanted more power.
I personally know of 3 Si's, 2 H22A's, a plethora of EX's, and a S2000 running 75 just fine.
DC5kid02
Jan 1, 2007 03:19 PM
nickdoe
Jun 3, 2003 08:05 AM
DK4200
Apr 6, 2003 04:24 PM
DaNish
Nov 22, 2001 07:21 PM
