need help with turbo manifold.
Old Jan 1, 2003 | 03:57 PM
tvrsir's Avatar
Default need help with turbo manifold.
i have a drag gen 3 kit from my previous car (00 si). now i have a 93 hatchback with a single vtec in it. what i want to do it throw the b series turbo into it for now until spring time when i drop in a b18c1 gsr. what i understand is that the manifold is not going to fit but everything else will. so where can a get a good turbo manifold that will fit my t3-to4e for a sohc vtec either cast iron or stainless steel. for around 500 and lower. if you guys know help me out thanks.
does drag gen 3 run the same turbo on there sohc and dohc?
Old Jan 1, 2003 | 04:16 PM
BudaKai's Avatar
Default Re: need help with turbo manifold. (tvrsir)
I'm not positive on this one, but someone here has used the DOHC manifold on the SOHC. Of course with slight modification. If so you wouldn't have to buy a new one then.
Old Jan 1, 2003 | 06:06 PM
tony1's Avatar
I have rev hard cast manifolds in stock for the 1.6. Give me a call at the shop if you need one.
Tony
972-278-9744
Old Jan 2, 2003 | 04:00 PM
tvrsir's Avatar
Default Re: need help with turbo manifold. (tony1)
can you please email me (tony1) with a price. oh i have heard that the rev hard manifold are better than the drag. THIS IS FOR A SOHC RIGHT? THAT YOU MIGHT HAVE In STOCK. LET ME KNOW. ALSO IF ANYONE ELSE KNOWS LET ME KNOW
GorData
Mar 27, 2002 10:47 AM
