need help on turbo build up
Old Jan 14, 2003 | 05:34 PM
civicguy's Avatar
Default need help on turbo build up
im looking for 300hp for now with the intension of more down the road my set up consist:
ls/vtec,9.0 je pistons,eagle rods,gsr cams and other goodies blah,blah...i will be using a rev hard manifold but don't know what size turbo do i need.Rev.limit will be 8,500 rpm using ls tranny.thanks in advance
Old Jan 14, 2003 | 07:20 PM
Rod Short's Avatar
Default Re: need help on turbo build up (civicguy)
Okay, I'll bite. are you looking for 300-hp at the front wheels or at the flywheel?
Rod Short
Sales Manager
Precision Turbo
Old Jan 14, 2003 | 08:27 PM
civicguy's Avatar
Default Re: need help on turbo build up (Rod Short)
im looking at 300 hp at the front wheel just to begin,then from there move up to 450 or so. i guess i will need a turbo that can support 450-500 whp,i was looking at the post about precision but im confuse about those.i dont mind a little lag,just something where i can get full boost at least at 4,500 rpm and hold on to 8,000-8,500 rpm
Old Jan 14, 2003 | 08:30 PM
EpDarks's Avatar
So you want a turbo that can support 300 WHP?? Or a turbo that can support 450 WHP?? Big difference.
Most of the T3/T4 hybrids will push out 300, but no where near 450.
You'll need something like a 60-1 or a T66 for 450 WHP.
Old Jan 14, 2003 | 08:34 PM
BudaKai's Avatar
Default Re: need help on turbo build up (EpDarks)
What? T3/T4's have been known to make up to 600WHP+ depending on trim and A/R on a a B18.
Old Jan 14, 2003 | 08:39 PM
*Boostwerks*'s Avatar
"T-66 for 450hp..."
WTF??
If this was not a mistake, you obviously have no idea what you are talking about...
jaynmeli
Aug 23, 2008 08:02 AM
EF9-CIVIC
Aug 23, 2006 07:45 PM
chitownrida
Mar 29, 2006 09:37 AM
CSRacing
Oct 19, 2005 05:27 AM
