Need help removing injectors from clips
Old Jul 3, 2004 | 01:33 PM
InLimbo87's Avatar
Default Need help removing injectors from clips
is there any sort of tab i have to press or something? Ive pulled, squeezed, yanked and they won't come out. i know there has to be a simple solution. thanks
Old Jul 3, 2004 | 01:50 PM
tyflip2's Avatar
Default Re: Need help removing injectors from clips (tegsedan)
obd1 or obd2?
Old Jul 3, 2004 | 01:58 PM
InLimbo87's Avatar
Default Re: Need help removing injectors from clips (tyflip2)
obd1
Old Jul 3, 2004 | 02:34 PM
vtec69's Avatar
usually the ob1 have like a lil metal bar(kinda like the thing thats on the chinese food containers) if you push that in towards the injector(should close to the head) it should pull right out.
If that doest work than just try to squeeze the sides of the clip and pull
-Brian
Old Jul 3, 2004 | 02:50 PM
sporkcrx's Avatar
Default Re: Need help removing injectors from clips (vtec69)
Just gently pull up on the clip, get a flathead screwdriver and push the end of the metal a little and it'll come off easily. Then to put it on, put the metal bar how it should be, and put it right back on and it clips into place.
Old Jul 3, 2004 | 02:51 PM
InLimbo87's Avatar
Default Re: Need help removing injectors from clips (sporkcrx)
thanks guys. i feel retarded for not thinking of that one. Honda-tech= awesome
Old Jul 3, 2004 | 02:54 PM
InLimbo87's Avatar
any of you know how much it is for a new seal kit from napa or something? I broke two of the small little washer seals, can i buy those seperate? Also, should the injectors sit flush with the manifold or stick out a little bit??
Old Jul 3, 2004 | 08:35 PM
InLimbo87's Avatar
bumpity bump-
Luke G.
Sep 4, 2010 05:14 PM
killerpenguin21
May 2, 2010 11:51 AM
vlc92189
21
Mar 6, 2009 12:06 PM
00Red_SiR
Apr 27, 2008 08:19 AM
ladysman
May 26, 2003 01:50 PM
