Need HELP picking turbo.
I need some help picking out the right turbo for my civic. Here's my specs:
b16a2 bored to 1.7
stock vtec head
Ross 9:1 pistons
Eagle rods
Re-balanced crank
650cc injectors
225 l/hr fuel pump
STR fuel rail w/ pressure reg.
hondata
tial 38mm wastegate
i think this should be enough.
My goal is 350whp. This is going to be a daily driver too, so i want a pretty good spooling turbo, maybe 3000-4000 max boost range.
Gimme your suggestions guys!!! thanks
b16a2 bored to 1.7
stock vtec head
Ross 9:1 pistons
Eagle rods
Re-balanced crank
650cc injectors
225 l/hr fuel pump
hondata
tial 38mm wastegate
A t3/t04e 50 comp and .48 a/r turbo should be able to do it with around 14-15psi of boost. It's always good to get a bigger turbo though... I would suggest maybe looking into running the Precision SC32 turbo. Ball bearing is a nice option, but with compressor wheels that fast traction is really going to kill you in 1st and 2nd gear.
ok cool. What about going bigger though? like .63 a/r turbine and .60 on the compressor? And anything on wheels? I definately want to go ball bearing.
