need help with msd btm insallation...
Old Mar 19, 2006 | 06:40 AM
RACEPAK's Avatar
Default need help with msd btm insallation...
hello everybody.
i need to install this msd boost timing master on my car.
i know that the coil is located inside the dizzy. but i dont know what its polarity, can anyone help? (red and orange wires on diagram)
and also what about the white wire? where to i need to tap it into?
whats "from points" ?
thanks
the diagram:
Old Mar 19, 2006 | 07:04 AM
ImportMotorSpec's Avatar
Default Re: need help with msd btm insallation... (RACEPAK)
Someone correct me if im wrong, going off my head.
White wire goes to - existing coil wire in dizzy, red goes to + existing coil wire
Should be a orange and a black left-orange is + on new coil and black is -
I am about 99.9% sure this is correct.
Old Mar 19, 2006 | 07:24 AM
DaveF's Avatar
Default Re: need help with msd btm insallation... (ImportMotorSpec)
the blk/yel is the + the blue wire is the -
hook the blk/yel to the red.
hook the white to the blue.
Old Mar 21, 2006 | 02:42 PM
RACEPAK's Avatar
Default Re: need help with msd btm insallation... (Dturbocivic)
:frustrated:
Old Mar 22, 2006 | 02:05 AM
DaveF's Avatar
what do you need to know?
Old Mar 22, 2006 | 05:36 AM
USDM 4G VTEC's Avatar
i had one installed before
that diagram is not the right one
i called MSD once and over the phone they helped me install it when i lost my papers once
call them up!!!!
Old Mar 22, 2006 | 06:48 AM
99lspwr's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ImportMotorSpec &raquo;</TD></TR><TR><TD CLASS="quote">Someone correct me if im wrong, going off my head.
Im pretty sure this is correct also...I can verify on my car for 100% tonight..
Old Mar 22, 2006 | 08:52 AM
EE_Chris's Avatar
Default Re: need help with msd btm insallation... (99lspwr)
MSD BTM p/n 5462 Instructions
Open up the distributor and take notice of the Blue (or Wht/Blu) wire leading from the ICM to the coil. This is the (-) coil lead. Cut it. The 1/2 that goes to the coil is what you connect to the Orange BTM wire. The other 1/2 coming from the ICM is what you connect to the White BTM wire. The Red BTM wire gets connected to the Blk/Yel wire, which is connected to the coil (+) as well as the ICM. You want to splice into this wire though, so as to leave its original connections intact to the coil and ICM.
Old Mar 23, 2006 | 07:39 AM
EE_Chris's Avatar
Default Re: need help with msd btm insallation... (EE_Chris)
Just wanted to throw up a pic for a better visual:
It seems there is/might have been some confusion. When people were mentioning having an Orn and Blk left over, it seems they assumed an actual MSD6A or similar ignition box was also already installed. I assumed he did not have one. So there really isn't wrong info given in here...it was for the assumed application that might have made it wrong.
Old Mar 24, 2006 | 03:45 AM
RACEPAK's Avatar
OMG thanks EE_Chris
Old Mar 25, 2006 | 03:39 PM
RACEPAK's Avatar
ok so i opend the dizzy and i i didnt found anything like in the picture above...
here are some pictures of my dizzy:
Old Mar 25, 2006 | 08:43 PM
xyzalvarez's Avatar
theres way too much difference between B and D series dizzy...
Old Mar 26, 2006 | 05:20 PM
RACEPAK's Avatar
Default Re: (xyzalvarez)
??<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xyzalvarez &raquo;</TD></TR><TR><TD CLASS="quote">theres way too much difference between B and D series dizzy... </TD></TR></TABLE> ?
Old Mar 26, 2006 | 11:13 PM
xyzalvarez's Avatar
i had the impression that the D series dizzy was almost the same shape as the B series...(im comparing the pic from EE_Chris and yours) but i was wrong...
it has to be the same conection basics, but different location..
https://honda-tech.com/zerothread?id=553249
bump!
Old Mar 27, 2006 | 03:23 AM
RACEPAK's Avatar
my engine is a D.... to be more accurate its a D14A4.
theres got to be a way to install it...... i just didnt found any mathood
Old Mar 27, 2006 | 11:55 AM
RACEPAK's Avatar
Default Re: (RACEPAK)
help bump
Old Mar 27, 2006 | 11:58 AM
EE_Chris's Avatar
Can you remove the wires from the coil area and take another pic? Can't really see how things are connected between the coil and ICM.
Old Mar 27, 2006 | 11:59 AM
RACEPAK's Avatar
Default Re: (EE_Chris)
ill do that right away
Old Mar 30, 2006 | 05:42 PM
RACEPAK's Avatar
i didnt had my camera
Old Apr 2, 2006 | 11:37 AM
RACEPAK's Avatar
the wires that you can see up there^^^ are the only wires inside the dizzy. (black and green)
frustration bump
Old Apr 2, 2006 | 02:35 PM
gnar kill's Avatar
that dizzy doesn't look anything like the one for my z6....
Old Apr 2, 2006 | 03:25 PM
RACEPAK's Avatar
Default Re: (gnar kill)
i know its a d14a4!!!
Old Apr 2, 2006 | 03:37 PM
xyzalvarez's Avatar
if u take the coil out, is there any conectors to the side?
yoffer
Aug 11, 2007 08:46 PM
kodirtysi
Oct 6, 2005 02:45 PM
giser
Sep 5, 2004 07:48 AM
BoostedSi
Oct 21, 2002 12:39 PM
