Need Help on H22A Turbo Set up
Old Sep 23, 2003 | 10:33 PM
Showoff's Avatar
Default Need Help on H22A Turbo Set up
Like Topic says i need advise on what parts to use and that will work well with...here a list of the things i'am planing to get what should i change or replace or use any other company that might be better etc please some pro's with soem good Help
Info on the Car its a 1995 Accord 4 door with an JDM H22A motor and type S Tranny
MOTOR
Arias Pistons 9:0 Compression (rings, wrist pins, locks)
ReSleeving hte blcok with Golden Eagle
Crower rods
Port Polish the head
AEM Cam Sprockets ? or use another
SuperTech Valves ? or use other brand ?
Eibach Valve Springs
Crower Retainers
Head Machining ( 3 angle valve job & seals)
ARP Head studs
Cosmatic Head Gasket
TURBO
Innovative Turbo 60-! T4 Duel Ball Bearing or should i go with an T3/t4 or T4 ?
Tubular Turbo maifold
Tial Wastegate ? or should i use another brand ?
Tial BlowOff Valve ? or should repalce with something else ?
XS Intercooler ? or use other brand ?
Apexi AVCR Boost Controller ? or replace with something else ?
FUEL
RC Engineering 720CC injectors
AEM Fuel Rail
Walbro In-Tank Fuel Pump
SPARK
MSD Digital 6
MSD SS COIL
MSD Coil wire Kit
ECU
Hondata S200 System
P28 OBD 1 ECU ? or use other ECU like 93 civic DX ECu ?
Motec 3 bar Map sensor ? or use something else like 300ZX TT or Supra TT ?
Old Sep 24, 2003 | 08:02 AM
Showoff's Avatar
Default Re: Need Help on H22A Turbo Set up (Showoff)
anyone ? this cant be a perfect set up ? any one with some feed back ?
Old Sep 24, 2003 | 08:11 AM
ekb18c's Avatar
looks good to me.
you want to use p28 ecu and a 3 bar map from ac/delco or from hondata
Old Sep 24, 2003 | 08:33 AM
Showoff's Avatar
Default Re: Need Help on H22A Turbo Set up (ekb18c)
Colin ..work will be done at the Shop do u think the turbo is go big for street set up ? looking to spool at or around 3,000-4,000 Rpms should i consider T3/T4 ?
Old Sep 24, 2003 | 08:36 AM
ekb18c's Avatar
dual BB? If yes it will be great for the street. t3/t4 is too small for h-series in my opinion.
Old Sep 24, 2003 | 08:43 AM
Pikachu's Avatar
I'm interested in doing a turbo setup as well but I'm left in the dark about engine reinforcement. I know I have to lower the compression of the engine but that's all I know. My goal is to push 15psi max but run like 7-8 psi on the street. Can anyone point me in the right direction?
Old Sep 24, 2003 | 08:45 AM
ChargedLude97's Avatar
Default Re: Need Help on H22A Turbo Set up (Pikachu)
Pikachu you need to get your blocked sleeved.
Old Sep 24, 2003 | 08:46 AM
ekb18c's Avatar
see above set up. It's good for a lot of power. After you see that setup then call me to set up an appointment.
Showoff's set up is a big boy block. We can customize any block to fit your budget.
Old Sep 24, 2003 | 08:47 AM
Pikachu's Avatar
Can I just come to you to get most of those parts as well?
Old Sep 24, 2003 | 08:50 AM
ekb18c's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Pikachu &raquo;</TD></TR><TR><TD CLASS="quote">Can I just come to you to get most of those parts as well?</TD></TR></TABLE>
Yes, you can. You can come to me for parts or for advice on your setup. You can even come to the shop if you just want to kick it for a bit.
Old Sep 24, 2003 | 09:02 AM
Pikachu's Avatar
Yea, I'll definately come by. What are the hours of operation for you guys?
Old Sep 24, 2003 | 09:08 AM
ekb18c's Avatar
10-7
Old Sep 24, 2003 | 09:10 AM
Pikachu's Avatar
monday-saturday or monday-friday?
Old Sep 24, 2003 | 09:11 AM
ekb18c's Avatar
m-s
Old Sep 24, 2003 | 11:16 PM
Showoff's Avatar
dont u guys think the T60 turbo will spool up tool late for street use ?
Old Sep 25, 2003 | 01:46 AM
rjardy's Avatar
no, gudeh23a just made some crazy HP with this turbo if I remember corectly. look for his post. 400+ to the wheels.
Rob
Old Sep 25, 2003 | 08:29 AM
Showoff's Avatar
Default Re: Need Help on H22A Turbo Set up (rjardy)
i guess everyone is ok wiht the head parts ? what about like JUN parts webCams etc ? no coments on that
Old Sep 25, 2003 | 09:30 PM
Showoff's Avatar
should i got with 9:0 compresion or at 10:0 ? (H22A)
how this sounds ? ....Valve Springs
Crower CNC Titanium Retainers
Crower Adjustable Cam Sprockets
Stainless Steel Valves --stick with CROWER ?
also Crower H22 DOHC VTEC Camshafts
Advertised Duration Duration @ .050" Gross Lift w/1.55
Int-297 mid Exh-287 mid Int-248 mid Exh-240 mid Int-.466 mid Exh-.465 mid would a street/strip set up be good ? (stage 2)
Modified by Showoff at 2:02 AM 9/26/2003
30psi_gst
Sep 24, 2011 03:55 AM
Garsis
Jun 13, 2005 10:24 AM
Showoff
Sep 30, 2003 05:11 PM
Showoff
Sep 29, 2003 09:29 PM
Showoff
Aug 25, 2003 08:56 AM
