Need help on building my head
Old May 16, 2013 | 08:56 AM
Big Rhag's Avatar
Default Need help on building my head
hi guys im building my h22 head for turbo and i dont know if i should use ferrea roller cams or not.
Im going for around 500 hp and can I use the bc turbo cam with those rollers or i need to buy another one
Old May 16, 2013 | 11:00 AM
h22apwrd95's Avatar
Default Re: Need help on building my head
Stick with the stock cams with an aftermarket spring/retainer combo. The port on those heads is more than capable to flow enough air for 500hp, and the stock cam matches up well.
Old May 16, 2013 | 11:13 AM
datbumper's Avatar
There's more important things to get first than cams. Ex: Pistons, rods, and possibly a sleeve job.
Old May 16, 2013 | 11:40 AM
grumblemarc's Avatar
The Grumpiest
Way to assume. He asked about the head, not the bottom end. How do you know what he does or doesn't have?
Old May 16, 2013 | 02:48 PM
Big Rhag's Avatar
Thanks but i already have the bc turbo cam so will a stock one perform better then the turbo cam and what about my rocker arms i should keep the stock one aswell?
Old May 16, 2013 | 02:49 PM
Big Rhag's Avatar
The block is fully built
Cp pistons
Carrillo rods
Darton sleeves
Arp main stud
Old May 16, 2013 | 02:56 PM
odz-fab's Avatar
if you have the cam already keep it simply and upgrade springs and retainers like one allready mentioned... roller cams and roller rockers are better by disign but not needed for what your aiming for.
Old May 16, 2013 | 03:07 PM
datbumper's Avatar
My bad. Are you already decided on Ferrea cams?
Old May 16, 2013 | 03:27 PM
Big Rhag's Avatar
I heard that using ferrea roller rockers will cause the engine to run sht at low rpm since its kills vtec is it true? And thanks alot for the replys:D
Old May 16, 2013 | 09:08 PM
h22apwrd95's Avatar
Yes, roller setups are usually meant for a single lobe cam. And "turbo" cams are not always better for power than an OEM cam. But it all depends on the setup. Manifold, turbo, downpipe/exhaust, all will weigh into the greater equation. Best way to know would be to tune on both sets of cams.
Old May 17, 2013 | 07:33 AM
Big Rhag's Avatar
Would you advise me to use the ferrea or the stock one better for this setup and thanks for the reply
Old May 17, 2013 | 10:35 AM
h22apwrd95's Avatar
The Ferrea roller rockers are not a "need" for your setup and your current goals. It is money better spent somewhere else in my eyes. It would require a custom cam, and that would be a single lobe cam that would hurt low range drivability and power.
Old May 17, 2013 | 01:20 PM
Big Rhag's Avatar
Alright thanks alot man
93b20z
Feb 3, 2011 04:12 AM
tersaydeez
Feb 14, 2008 07:34 AM
CeeJayy
Feb 26, 2007 03:09 PM
Pfieff
Apr 23, 2004 11:08 AM
DC2NR
Jun 17, 2003 05:05 AM
