need help with block set up ASAP
Old Sep 21, 2001 | 09:50 PM
JimmieD's Avatar
Default need help with block set up ASAP
I am looking at a block with crower rods and srp pistons. it is set up @10.5 compression. DO you think this is going to be too high for FI with a hondata ecu. i was planning on 10:1 anyways but 10.5 adn teh pistons being SRP is kinda scaring me. How hard would it be for me to swap out some different pistons to my liking. what parts would i have to replace in the swap? any help is greatly appreciated.
Old Sep 21, 2001 | 10:19 PM
TurboInteg95's Avatar
Default Re: need help with block set up ASAP (lsinteg)
a piston swap would be easy if you're really worried about it.
Old Sep 21, 2001 | 10:52 PM
Blown90hatcH's Avatar
Default Re: need help with block set up ASAP (TurboInteg95)
Yeah, the pistons are easy to change. I think that 10.5:1 compression is too high for Hondata
Old Sep 21, 2001 | 11:30 PM
Turbo00's Avatar
New User
Default Re: need help with block set up ASAP (Blown90hatcH)
i know JE and SRP are the same company. but isnt the material in the JE's better than the SRP's
Old Sep 22, 2001 | 12:08 PM
JimmieD's Avatar
Default Re: need help with block set up ASAP (Turbo00)
Thank you guys. I know the JE is a better material, my main question was about the compression. so i appreciate the responses. Can anyone fill me on what is needed to replace the pistons? some steps? Also, i take it nothing will have to be replaced. thanks again.
Old Sep 23, 2001 | 08:08 PM
Dont worry about them being SRP. Unless, you want to boost like a man. But, as far as, swapping them go, I would get new rings with your new pistons and dingle ball hone it to clean it up a little. Get a chiltons..works everytime.
HTH
Old Sep 23, 2001 | 08:16 PM
JimmieD's Avatar
well i want to run atleast 15 lbs or so i dont think i will using hte srp's. I ahve a friend who is interested so he will buy them and i will pick up some new 10:1 ratio ones, problay wiseco or JE's
tootybaby
22
Apr 18, 2012 08:01 AM
James_Starks
16
Sep 27, 2010 09:05 PM
Circusraven
Jun 22, 2008 01:40 PM
4cefedcrx
Nov 30, 2003 09:12 PM
