need help bad!!!!
Old Jul 26, 2002 | 04:44 PM
KLN's Avatar
KLN
Default need help bad!!!!
i had an oil leak, and i just found it!!!...my "T" off the back of my block broke off, and now the thread is stuck in my block...how can i get it out? i can't believe this happened to me!!!
please help!!! any info would be appreciated
Old Jul 26, 2002 | 04:48 PM
HXMan's Avatar
Default Re: need help bad!!!! (KLN)
Hmmmm......sounds like you need a bolt extractor or something.
Old Jul 26, 2002 | 04:50 PM
Farnsrocket's Avatar
Default Re: need help bad!!!! (HXMan)
Is any of the "T" sticking out past the block that you can grab with some visegrips?
[Modified by Farnsrocket, 5:50 PM 7/26/2002]
Old Jul 26, 2002 | 05:09 PM
rjardy's Avatar
helicoil (sp) you can get them at your local parts store, it kinda looks like a drill bit that you put in there and it grabs the peice and you run it out. Do allot of people have a problem with this?
Rob
Old Jul 26, 2002 | 05:13 PM
KLN's Avatar
KLN
Default Re: need help bad!!!! (rjardy)
will that helicoil work even with my engine still in? because there is very limited space...
pretty much the whole threading is stuck in the block, nothhin' is stickin' out far enough to grab
Old Jul 26, 2002 | 07:44 PM
And it's hollow, correct?
Can you get a small screwdriver in, and then wedge it in and then turn the threaded piece out with the screwdriver wedged in there?...you may not have enough room to
do this. I thought those helicoils just added new threading for a stripped out hole.
Old Jul 26, 2002 | 08:04 PM
racecarpete's Avatar
Default Re: need help bad!!!! (Farnsrocket)
that would be correct, helicoils only add new thread when it is stripped. What you actually want is an easy-out or screw extractor. They are found at the local hardware store. The screwdriver trick might work but most likely you will have to get an easy-out.
Old Jul 26, 2002 | 08:09 PM
Mr. Softee's Avatar
Default Re: need help bad!!!! (SilverCivic2k)
umm, you didnt run your car with no oil going to the turbo did you?
Old Jul 26, 2002 | 08:18 PM
KLN's Avatar
KLN
Default Re: need help bad!!!! (94goldjungsr)
i have a question...if i was to push the bolt all the way in, where would it go? oil pan?
no i wasn't runnin' the oil with no turbo, everytime i drove the car oild would start drippin', so i thought it was a simple leak, i was gonna redo all my oil lines when my "T" just fell off with an easy pull....
Old Jul 26, 2002 | 09:10 PM
It would be in your block, kinda trapped.
Old Jul 26, 2002 | 10:32 PM
boostinb18's Avatar
ok.......go get a EASY OUT!!!!! it will work great gaurantee!! they have reversed threads so it will thread into the broken tee and then when it goes in enogh it will just back the tee out!!! very easy....i use them all the time!! i had a broken bolt on my clutch and i pulled it right out with the easy out.
good luck!
Old Jul 26, 2002 | 10:47 PM
rjardy's Avatar
Default Re: need help bad!!!! (boostinb18)
damn im dumb, im glad someone caught that,
easy out not helicoil.Thanks on me again
Rob
Old Jul 28, 2002 | 07:47 PM
ion_four's Avatar
If you use an easy out, just make sure you don't break it off, like someone did in my manifold! I got it out with the aid of a drill press and fuggin blowtorch, but it sucked.
I think the moral of this story is to not put a T directly onto the block. Do the install as described on the endyn site and run a hose from the block to the T mounted to the firewall, so there's no stress on it.
Old Jul 28, 2002 | 07:53 PM
PrecisionH23a's Avatar
i was putting in my buddy's T and the damn copper piece snapped off and i was in the same boat you were in. It was VERY easy to extract, as stated before get the easy out or whatever the hell its called. Hammer it in good then unscrew it from the hole. easy as pie
Old Jul 28, 2002 | 08:06 PM
Ri5e's Avatar
Default Re: need help bad!!!! (GudeH23a)
SAME Exact thing happened to me. Thats why I run an oil line off of that, up to the top and T it from the TOP. The BRASS T's are BRITTLE and WILL Break off, especially if you have a heavy item on it like the Autometer oil sensor. When you shift hard it will rattle it and break it.
To remove it, you can DRILL IT OUT. However you have to be very careful when doing that. Use the smallest bit then move upwards until you get the bit that is a perfect fit. Then drill .... it'll make the brass threads weak. THen you can pry it with a thin flat head. Don't use a bit that is too big or you'll drill all the threads on the block...
Skatnshawn
Mar 24, 2013 12:25 AM
Br1gHtDc2
Nov 13, 2008 07:22 PM
hondacivic4g
May 27, 2004 09:37 PM
boosted_dc2
Mar 12, 2003 02:44 PM
