Need Help ASAP
Old Feb 5, 2006 | 07:02 AM
uncontrolled515's Avatar
Default Need Help ASAP
ok friday nite i boosted my 98 civic coupe "HX' D16Y5, the kit includes the following T04E (T25) with screen for intake opendownpipe costom 4in thick intercooler 27 long 6 high, RFL BOV, Missing link and BLOX FMU..... im having bad idol problems the car is fine when under boost but when i let off the gas and have the car out of gear when slowing down it wants to cut out, or go down to like 0-200rpm then it will rise back to idol or cut off so i have to let off the clutch at like 1500-1000rpm as i stop, the spark plugs are gaped at .32, its throwing a EGR valve code and a secondary O2 code but its not putting it into limp mode so i could car less about that, when the car idols after start up it idols around 750-900rpm steadyly.... anyone know what it could be? im on 93 octain with @7psi
Old Feb 5, 2006 | 06:01 PM
xenocron's Avatar
Default Re: Need Help ASAP (uncontrolled515)
What are you using for management...?
Fix your damn codes!
Old Feb 5, 2006 | 06:08 PM
Hybrid_Coupe's Avatar
figure out why your throwing an egr code...was it there befoer you boosted the motor? The secondary o2 sensor code is a given unless your running a cat. which obviously your not considering its open downpipe. And...before anyone else says it...get soem management on that thing...
Old Feb 5, 2006 | 06:10 PM
A2gt35r's Avatar
Close that DP. The wideband can't read an un pressurized exhaust.
Old Feb 5, 2006 | 07:44 PM
lol really? i run open downpipe...my buddy david runs open down pipe...whats the problem with open downpipe? a wideband reading has nothing to do with how much pressure is in the exhaust.
Old Feb 5, 2006 | 08:24 PM
Default Re: (Hybrid_Coupe)
well the codes its throwing are the EGR i know what that is its pritty much fixed im missing a vac line from under the fuel rail and also goes to a a thing on the firewall next to the battery... so its only throwing a secondary o2 i got the odol problem fixed i think its no in limp mode wehn the egr code was on its now at 5psi i got the FMU and missing link on the car right now till i get the money for Emanage or chrome.....what else beside what i have done will better tune the motor for the boost, i got the distributer kicked forward like 2 degree i got the sparkplugs gaped .32 i reset the ecu.....
93jdm_civic
Jan 27, 2010 07:51 PM
DarkBB4
Aug 27, 2005 09:31 AM
coolme
Mar 3, 2004 05:23 AM
