Need Help
I'm interested in turboing my civic and wondering with stock internals what all would I have to do to only want to run 7psi? What would need to be upgraded? I am running a d16z6 engine all stock. Thank you for your help
Fuels one of the biggest things. There are basemap ecus, afc's, hondatas great. Ur going to need injectors, some bkr7e ngk plugs are always good. Just Let us know here at neukin if we can help you with anything.
Modified by NEUKINAS at 4:59 PM 6/3/2008
i'm thinkin of running a t3/t4 turbo that my brother has.... we have just rebuild the entire engine from ground up with all OEM parts. With 230,000 miles on it the cross hatch makes were still in the cylinder walls which was very very surprising to me. The kit that he has comes with cast iron mani, t3/t4 turbo, downpipe with flex pipe, ssqv blow off, waste gate, oil feed and return, intercooler and piping.... don't have injectors but he said get some eclipse ones from the turbo and will do the job. Now my questions about this are: Do i just install the injectors and be done? or do i need to wiring something in? and where do i get the oil feed from? Do a sandwich between the block and oil filter or tap off the OSU? Also I'm working on a budget too. What way to kind of keep it cheap? I have 3 midgets.
rocker_boy_22
Jul 4, 2012 01:51 PM
