need help with 14b turbo setup on prelude
Old Mar 10, 2004 | 03:44 PM
7808's Avatar
Default need help with 14b turbo setup on prelude
i putting together a cheap turbo kit for my F22a1 96 prelude,
i got a 14b with 35k off a imported 4g63 (i was told ) anyways am i gona want to use the stock dsm exaust o2 housing? and will i need a downpipe? i dont know much.. its a learning experience.
anyways i got a 14b, 1g eclipse manifold, dsm blue top 450cc's, soon to be buying a smaller FMIC(jonny race car 5" maybe) looking for piping, walbro pump, probly gona use V-FMU. anyone wana give me some tips please do..
Old Mar 10, 2004 | 03:47 PM
USDM 4G VTEC's Avatar
Default Re: need help with 14b turbo setup on prelude (fuctup)
if it clears on ur car yea.. use that and just make a downpipe
on my case... i am having a hard time since it might hit my xmember
Old Mar 10, 2004 | 04:34 PM
b16ahybrid's Avatar
Default Re: need help with 14b turbo setup on prelude (USDM 4G VTEC)
Please do yourself and us a favor. Research about turbo's and turbo set-ups before you attempt to do this "project".
Learn and use the search function it will become your best friend.
Old Mar 10, 2004 | 06:13 PM
7808's Avatar
Default Re: need help with 14b turbo setup on prelude (b16ahybrid)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b16ahybrid &raquo;</TD></TR><TR><TD CLASS="quote">Please do yourself and us a favor. Research about turbo's and turbo set-ups before you attempt to do this "project".
Learn and use the search function it will become your best friend. </TD></TR></TABLE>
this is me researching... i did search this also. thanks for your help!
Old Mar 11, 2004 | 05:27 AM
blown_LS's Avatar
I got that turbo on my dsm (came stock) and it sucks *** on top end. I mean you will spool it up really really fast but it will fall on his *** before 6k rpms. Just my .02 cents
Old Mar 11, 2004 | 04:38 PM
b16ahybrid's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fuctup &raquo;</TD></TR><TR><TD CLASS="quote">
this is me researching... i did search this also. thanks for your help! </TD></TR></TABLE>
Really? Why are you going with that turbo? kinda small for your engine. Plan to use the fmu with the 450cc injectors?How do you plan to tame those injectors?
You asked for tips and I gave you some, so don't get all hurt when advice is given to you. It wasn't meant to be derogatory, it was intended to be helpful. Since your not looking for advice, good luck on your project
Old Mar 11, 2004 | 05:49 PM
pollito's Avatar
As people have said. That turbo will spool it's *** off, and fall off badly on the top end. Get a bigger turbo. What you should worry about first, because it is the most important, is fuel management. Don't skimp on it.
Old Mar 13, 2004 | 04:16 AM
7808's Avatar
Default Re: need help with 14b turbo setup on prelude (pollito)
ya i've got plans for fuel managment.
as far as the turbo, im not lookin for to much, just my car is slow i want it to be quik - not fast cause thats expensive and i'm not in a position to drop a load of money on my car right now, just want to do a basic turbo setup .
Old Mar 13, 2004 | 06:32 AM
b16ahybrid's Avatar
I would recommend plotting that compressor map against the engine, You may decide to go with another turbo.
It may not be worth the time and effort for you to fabricate a kit for that turbo/engine. At least I would recommend a 3 turbo that way when you get power hungry (and trust me you will) you can just upgrade the turbo only, not the turbo and manifold.
Old Mar 13, 2004 | 10:03 PM
7808's Avatar
a manifold is like $40 for a 14b cause a dsm one fits if you redrill the holes.. i was just gona get little better than i need parts so i can upgrade the turbo and manifold later if i want..
h22_crx
Apr 22, 2007 10:39 AM
Memi
Apr 21, 2006 06:15 AM
playboyillusion
Jul 3, 2004 02:52 PM
self_made
Sep 30, 2002 11:10 AM
Butthead
Nov 7, 2001 06:29 PM
