need help
Old Nov 15, 2005 | 09:37 PM
mugencivic94's Avatar
Default need help
i have a d16z6 with greddy 15g hondata rc 440s crane cam external coil msd wires and i went to take my friend for a ride bc just recently got my car finished and i get on it and it doesnt feel like its got the power. no boost leak and its not overheating or no oil in coolant or vice versa the only thing i know that might be is i might have gotten bad gas or the wrong grade by mistake. but if thats the case would it have power loss
Old Nov 16, 2005 | 04:57 AM
The Weather Man's Avatar
Problems:
1: its a 15g
2: is it tuned?
3: its a d16z6 <---just kidding but that motor with that small turbo = small gains
4: is it tuned?
5: is it tuned?
6: Can you hear the bov?
7: check your wastegate
Would it have power loss? answer - yes. Reason - if you went with a lower grade gas, you might have a lot of pinging going on - detonation and you know, **** like that. Assuming your knock sensor is working - it will retard the timing, giving you sluggish runs. Whats your best bet? just let the car run.....let the gas run out, or try to drain the gas into a tank or something. Then refill with high octane petrol.........
Or, you can try a combination of 94 octane mixed with whatever gas you have now - along with some octane boosters.....hopefully to get it to atleast 91. then you should be good.....
Is the car tuned at all?
Old Nov 16, 2005 | 06:44 AM
Default Re: need help (mugencivic94)
yes the cars tuned , the cars tuned and yes the cars tuned lol. i went this morning and changed my fuel filter and put in octane booster and toped tank off and now it feels good again atleast for now. but thanks but by the way the cars tuned
Old Nov 16, 2005 | 06:47 AM
Once it gets to half put more gas in it - higher octane. You should be fine. Glad we could help.
XanderTurbo88
Oct 31, 2008 06:01 PM
ZC-EG-6
Aug 22, 2005 10:34 PM
Basically
Nov 6, 2004 08:52 PM
NonovUrbizniz
May 3, 2004 06:04 PM
td04civic
Dec 9, 2001 01:02 AM
