Need Clutch Information!
Old Aug 29, 2002 | 05:06 PM
AB16A2T's Avatar
Default Need Clutch Information!
Who makes a good clutch that will hold 300+ HP?
Old Aug 29, 2002 | 07:10 PM
redteg1's Avatar
Default Re: Need Clutch Information! (AresB18BTurbo)
ACT Xtreme pressure plate and ACT Maxx pressure plate. you pick disc or puck combination with that.
Old Aug 29, 2002 | 07:20 PM
Flamenco-T's Avatar
Default Re: Need Clutch Information! (redteg1)
clutchmaster stage 5, 3 pucks unsprung disk...
now, that's some *****.....
actually I like it, I drive around in traffic with it...
Old Aug 29, 2002 | 07:30 PM
fast[R]'s Avatar
Default Re: Need Clutch Information! (Flamenco-NA)
Realy I dought you like the stop and go on trafic. I hate my clutch, too much jurking or shurping only stage 3 but it does it's job on holding the power.
Old Aug 29, 2002 | 07:32 PM
AB16A2T's Avatar
that is insane for me, would a clutchmaster stage 2 hold 300+?
Old Aug 29, 2002 | 07:35 PM
Flamenco-T's Avatar
Default Re: Need Clutch Information! (fast[R])
I like the way it grabs, the pressure plate is not bad at all....more likte the ACT extreme PP, I am used to it grabbing....
stan
Old Aug 29, 2002 | 08:16 PM
Turbo_Si's Avatar
What do u guys think of EXEDY organic? it says that it is good to for 300whp.
im thinking of getting an EXEDY 3 puck for my daily driver/weekend warrior turbo Si. im aiming for 250-300whp with 10-12psi t3t4
i already have the exedy 3 puck pressure plate and im using my stock disc, so far it holds (not good but it holds), im debating whether to go with organic or 3 puck.
Old Aug 29, 2002 | 08:39 PM
Ri5e's Avatar
Default Re: Need Clutch Information! (Turbo_Si)
I have the Clutchmasters Stage 4 and holds all the power. Pedal pressure is like stock, unlike ACT...
However I think the Clutchmasters Stage 5 would be even better, although it doesn't last that very long.
Old Aug 30, 2002 | 12:32 PM
JDEM1's Avatar
Default Re: Need Clutch Information! (BG Boost)
my exedy sucks... cant hold worth crap .. getting a cm stage 3
Old Aug 30, 2002 | 02:30 PM
boostaholic's Avatar
No the CM stage 2 won't hold 300whp. It starts slipping even over 210whp. Look into a CM stage 4/5 or ACT extreme pressure plate w/ a puck disk.
Old Aug 30, 2002 | 03:08 PM
GSRwBOOST's Avatar
Default Re: Need Clutch Information! (boostaholic)
ACT Extreme PP w/ 6 puck unsprung.... it's the ******* bomb!!!!
holds all the power up to 400lbs of torque
Streetable, and you'll get use to the pressure increase....
Old Aug 30, 2002 | 04:23 PM
liam821's Avatar
Default Re: Need Clutch Information! (GSRwBOOST)
thats a little crazy for me...to unsrung pucks for me...
I have a jun flywheel with a ACT Xtreme pressure plate and the HD sprung street disc. It holds all the power i can through at it..super easy to drive around in traffic, you can slip this clutch there is no chatter. You could give the clutch to your grandmother and she would be happy to drive it...although then the stiff peddle.
liam
Old Aug 30, 2002 | 05:24 PM
AB16A2T's Avatar
it is going to make me feel like my clutch is ripping apart cause of the chatter? how much of a pressure increase?
Old Aug 30, 2002 | 08:31 PM
Kengs's Avatar
Cusco/OS Giken Super Single (sprung metal disk) is good for 400hp; ask Dee about his...
DeLucia
Apr 16, 2010 09:14 AM
juergen33911
Jul 9, 2008 11:16 PM
Rhymenoceros
16
Apr 21, 2007 06:42 AM
civicduty13
May 1, 2005 08:29 PM
Bbasso
Jan 22, 2002 07:30 PM
