need Accel DFI gen 7 help ! ! !
Old Apr 2, 2003 | 03:01 PM
civic disobedience's Avatar
Default need Accel DFI gen 7 help ! ! !
just picked up my DFI today, and already running into issues, the Ignition plug doesnt plug in, wrong connector, and same deal with the TPS, my dealer is going to call tommorow morning and try and get some anwsers, but if anyone is using this management system I just want to know if you had the same problems? do they make an adapter harness?? please chime in if you know!!
Old Apr 2, 2003 | 03:13 PM
boostaholic's Avatar
Default Re: need Accel DFI gen 7 help ! ! ! (civic disobedience)
Do you have a honda specific wiring harness? Usually the dfi's and speedpro systems come with gm style plugs so you either have to make your own harness or order one pre made to honda type connectors.
Old Apr 2, 2003 | 03:15 PM
SIXTYdashONE's Avatar
HT's Biggest Loser
Default Re: need Accel DFI gen 7 help ! ! ! (boostaholic)
Check yer PM
Old Apr 2, 2003 | 03:23 PM
ekb18c's Avatar
Who's doing the wiring? And who did you buy it from?
Old Apr 2, 2003 | 03:55 PM
Default Re: need Accel DFI gen 7 help ! ! ! (ekb18c)
I am wiring myself, I wire broadcast systems for a living, and have worked on cars for as long as I can remember (even did it full time for a little while) so I feel I am capable. I bought the system from bruces speed shop in Rockaway NJ...
Old Apr 2, 2003 | 03:59 PM
ekb18c's Avatar
Wiring up dfi on a honda is a little more involved then just wire and plugs you must modify the distrubuter add some relays and some solennoids etc... And if you are trying to graph the two harness together you need to know what each damm wire goes where on both of the harness. It's gets confusing...
[Modified by ekb18c, 5:01 PM 4/2/2003]
Old Apr 2, 2003 | 04:04 PM
HT's Biggest Loser
Colins right man, i went through hell with mine, and needed assistance. I told you in the PM about the distributor and relays, as mentioned above. BTW, not to startle you, but if some wires are wired the wrong way, you can easily fry your DFI Brain, ive seen it happen, so take some early precautions.
Old Apr 2, 2003 | 04:15 PM
Default Re: need Accel DFI gen 7 help ! ! ! (SIXTYdashONE)
thanks for the input guys, I am going to get in touch with the guy at accel tommorow, my dealer said he would hook me up with his contact, I will let you know how it goes,
Ron, shoot me a PM tommorow when you have a few minutes to chat
Old Apr 3, 2003 | 01:48 PM
turbo Si's Avatar
On my '99 Si I recieved a Chevy wireing harness. Here are a few numbers you should keep on hand
1-248-380-2780
1-248-380-1512
you will get all your answers through those numbers.
Good luck!
Old Apr 3, 2003 | 02:17 PM
Default Re: need Accel DFI gen 7 help ! ! ! (turbo Si)
If i remember correctly, mike (ninesecrx) posted up a wiring diagram for honda's using the DFI setup. The archives are down but if you pm him i'm sure he still has that wiring diagram.
Old Apr 3, 2003 | 04:02 PM
I called them today, they were very helpfull, and I thought Mike was the one with the diagram, I will PM him tommorow when I have some time, unless you see this (mike) if you could E-mail it to me that would be great!!
Old Apr 3, 2003 | 05:04 PM
HT's Biggest Loser
Hey man, i have the wiring diagram also, whats yer email, ill send it to you, although, its for the 6.0, so i dont know how helpful its going to be, i dont know alot about the 7.0.. Colin would be the man to ask IMO. but regardless, i can send you the diagram..
Old Apr 3, 2003 | 05:10 PM
lsvtecvx's Avatar
hey. sixty I got 6.0 Im gonna be putting in my EG, can you PM me when you get a chance, so we can chat?
Old Apr 3, 2003 | 05:27 PM
turbo Si's Avatar
Default Re: need Accel DFI gen 7 help ! ! ! (lsvtecvx)
If you want I can print out the wireing diagram. I believe it's in the program that the unit comes with. I'll check when i get home.
Old Apr 3, 2003 | 05:59 PM
HT's Biggest Loser
Old Apr 3, 2003 | 07:42 PM
lsvtecvx's Avatar
Ive got a pin out sheet, I guess my only question is, for the injectors
the sheet I have says....
D15 Inj bank A-H
D16 Inj bank B-H
C15 Inj bank A-L
C16 Inj bank B-L
Now my question is,
I assume this means Bank A is cyl. 1-4, and Bank B is 2-3.
The guy I bought it from labeled Inj. 1,2,3,4. But since this isnt a seq. system I knew something was wrong, so am I right in my assumption
Old Apr 4, 2003 | 02:39 PM
h22 civic's Avatar
i also have a dfi 7.0 on a honda and had a plug and play harness made but i need to have my distributor modified and run a relay to change the pularitys of the vtec switch can any body plese help
??????????any info is greatly apreciated
Old Apr 4, 2003 | 02:57 PM
Default Re: need Accel DFI gen 7 help ! ! ! (h22 civic)
havent gotten that far yet, but all you have to do is call the numbers listed above, they will tell you exactly what to do
oops, I thought someone posted the #s, I dont have it here, but if you go to the mr gasket website, follow the links to accel dfi, and search around, there is a number, its 248 something something yada yada, just look around
[Modified by civic disobedience, 7:02 PM 4/4/2003]
Old Apr 4, 2003 | 03:22 PM
turbo Si's Avatar
1-248-380-2780
1-248-380-1512
Good luck!
There still here!!
Old Apr 4, 2003 | 03:57 PM
yea thos #s... sorry been a long day!!
Old Apr 4, 2003 | 06:00 PM
Pelican's Avatar
hey. sixty....
a dime better than the rapper on Shady Records
just made me laugh. Met him a couple of weeks ago.
Old Apr 11, 2003 | 06:17 PM
h22 civic's Avatar
all stand alones suc pure **** nothing but headaches any body that says diferent their cars probally sit in their shops doing nothing and drive em once a yearthis is from personal experiance all you do is wait for a installer or tuner to learn how to use it... its all about the money and whos trying to cut whos throught
Old Apr 14, 2003 | 06:21 PM
h22 civic's Avatar
Default Re: (h22 civic)
wow i was pissed that nite
JuicedUpRice
Audio / Security / Video
Dec 18, 2012 06:07 PM
So Live
Feb 10, 2009 07:17 AM
this1drumma
Mar 5, 2008 02:07 PM
higgunscrx
Sep 4, 2006 07:04 PM
crashtest Sonny
Dec 1, 2002 04:47 PM
