Necessary Gauges for Supercharger?
Old May 26, 2004 | 07:30 AM
CPR's Avatar
CPR
Default Necessary Gauges for Supercharger?
Old May 26, 2004 | 08:07 AM
sway892's Avatar
Default Re: Necessary Gauges for Supercharger? (CPR)
oil pressure
boost
air to fuel
that's for starters anything after that is up to you
Old May 26, 2004 | 09:12 AM
CPR's Avatar
CPR
Default Re: Necessary Gauges for Supercharger? (lexvdub1)
Why oil pressure? Isn't that more important for turbos?
Old May 26, 2004 | 09:52 AM
Blue-Civic-Hybrid's Avatar
Loved
I currently have no gauges set up on my JRSC'd Civic, but I do want to install a boost gauge( which I have sitting in my garage just staring at me), water temp and maybe a 3rd gauge....
I would probably just recommend a boost gauge.
Old May 26, 2004 | 12:37 PM
sway892's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Blue-Civic-Hybrid &raquo;</TD></TR><TR><TD CLASS="quote">I currently have no gauges set up on my JRSC'd Civic, but I do want to install a boost gauge( which I have sitting in my garage just staring at me), water temp and maybe a 3rd gauge....
99% of hondas have a water temperature gauge
If you get an oil pressure gauge, you'll eliminate the computer doing your work. Unless you have vtec, it may be real late when the computer tells you that your oil pressure is low.
If you have VTEC, your check engine light usually comes on and tell you that it's not getting enough oil
Old May 26, 2004 | 01:41 PM
Loved
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lexvdub1 &raquo;</TD></TR><TR><TD CLASS="quote">
Have you seen how inaccurate the water temp gauges are on the gauge clusters?? On my Hondata with my laptop hooked up, I can see variances of 20 to 50 degrees in water temp while the needle on the water temp gauge stays the same.... Maybe you don't need to know the difference, but I do.
BUBBLE BOY
Sep 23, 2006 09:46 AM
cibola
13
Jun 23, 2005 11:43 AM
97dc2
May 24, 2005 03:36 PM
B00ST2nR
Jun 8, 2004 07:07 AM
TwistedSI
12
Mar 11, 2004 09:15 PM
