NA to Boost, Dyno numbers on 7psi
Old Nov 15, 2004 | 10:50 AM
AzG35's Avatar
Default NA to Boost, Dyno numbers on 7psi
Well, I made the changeover from NA to boost this weekend. My motor is a poor man's type-R. Originally it made 200hp and 137 torque NA with 12.0:1 CR. I decided I was done with it so I changed over. I added a Cometic .074" head gasket to drop the compression to about 10.5:1 CR and threw in a set of GSR cams instead of the Skunk Stage 1's I had. Unfortunately I left the dyno sheet at home, I will post it tonight. Here is the setup now:
B18C1 block, JE pistons, GSR rods w/ ARP rod bolts
B16A head, ported/polished, GSR cams
Cometic .074" head gasket, total compression ~10.5:1
Garrett T3/T04e 50 trim, .63 A/R turbo
Tial 38mm wastegate
Revhard manifold and 2.5" downpipe
Kteller 2.5" catback (2.5" magnaflow muffler and resonator)
Spoolin Performance I/C piping
6" JohnnyRacecar intercooler
Greddy TypeS BOV
TurboXS MBC
Lucas 440cc injectors
Walbro 255lph fuel pump
AEM FPR
Hondata s200b
On 7psi I ended up putting down 261hp and 191 torque on 91 octane on full exhaust. I will get the graph up later. Injectors are maxxed out (90-93%) I need to get at least 550's or higher. Fuel pressure is up there too ~60psi A/F was tuned to a conservative 11.5:1 due to the high compression. Timing was about 22-23 degrees. I am going to go with bigger injectors and up the boost later. Do these numbers sound about right?
Edit: Here is the graph compared to my all motor numbers. There is a slight dip in the 6500-7000 area for some reason. A/F looked good there and so did timing. Kinda weird.
Put some RC750's in and bumped the boost up to 10psi. Pulled 301hp and 230 torque.
Modified by AzSi22 at 12:49 AM 11/25/2004
Old Nov 15, 2004 | 10:51 AM
FOrSfEd's Avatar
Default Re: NA to Boost, Dyno numbers on 7psi (AzSi22)
not to bad on the low boost, turn it up a lil more and you should be over 300 easy.
Old Nov 15, 2004 | 10:52 AM
-iLLuZioN-B18C1's Avatar
i say those are nice numbers!!
compression makes a world of a difference
i say those numbers sounds about right for your setup
Old Nov 15, 2004 | 10:56 AM
fast94ex's Avatar
Default Re: NA to Boost, Dyno numbers on 7psi (-iLLuZioN-B18C1)
Old Nov 15, 2004 | 11:08 AM
RobbieG35's Avatar
12 Years Strong
Default Re: NA to Boost, Dyno numbers on 7psi (fast94ex)
Any pics of the car?
Old Nov 15, 2004 | 11:14 AM
AzG35's Avatar
Default Re: NA to Boost, Dyno numbers on 7psi (HybridHatch88)
Here is the most recent pic:
With the I/C in, you can't tell. The only thing that gives it away is the I/C piping because I had to cut the bumper some for the piping to clear.
Old Nov 15, 2004 | 11:16 AM
mattEG's Avatar
That car is ******* sexy! Nice!
RobbieG35's Avatar
12 Years Strong
Looks good
Old Nov 15, 2004 | 11:18 AM
project dc2's Avatar
looks good
Old Nov 15, 2004 | 11:23 AM
BoostedsiR's Avatar
Default Re: NA to Boost, Dyno numbers on 7psi (project dc2)
looks good and good numbers on low boost. crank that **** up
Old Nov 15, 2004 | 11:51 AM
hybrid93SIvic's Avatar
Default Re: NA to Boost, Dyno numbers on 7psi (BoostedsiR)
adam...nice numbers....i will sell you my 550's...they used to be yours....brand new...$250
AzG35's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BoostedsiR &raquo;</TD></TR><TR><TD CLASS="quote">looks good and good numbers on low boost. crank that **** up </TD></TR></TABLE>
I will, once I get some 650cc or 750cc injectors
Old Nov 15, 2004 | 11:52 AM
well n/m on the 550's then....
Old Nov 15, 2004 | 11:54 AM
boostjunkie757's Avatar
odd....
im running RC440's on a stock ITR turbo with a headgasket at 9.1:1 and on 7psi i put down 307 to the wheels...
you say your 440's are maxed? imagine how mine feel....
Old Nov 15, 2004 | 11:59 AM
AzG35's Avatar
Default Re: (boostjunkie757)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boostjunkie757 &raquo;</TD></TR><TR><TD CLASS="quote">odd....
you say your 440's are maxed? imagine how mine feel....</TD></TR></TABLE>
My duty cycle was close to 100% at one point when my car was still in the high 10's in A/F. I also tuned to 11.4-11.5:1 CR to be safe. I'm sure there is more HP just from going a bit leaner, but I don't want to push it yet.
Old Nov 15, 2004 | 12:01 PM
DanishR's Avatar
Do you like the way the car drives with boost? Sure it has more power, but what about lag? Could you do a little NA to Boost review?
Old Nov 15, 2004 | 12:02 PM
Default Re: (DanishR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DanishR &raquo;</TD></TR><TR><TD CLASS="quote">Do you like the way the car drives with boost? Sure it has more power, but what about lag? Could you do a little NA to Boost review? </TD></TR></TABLE>
his car was insanely fast to begin with....i am sure it is a lot more fun now though
Old Nov 15, 2004 | 12:05 PM
RobbieG35's Avatar
12 Years Strong
Turbo lag is way overblown, sure you have to wait a second for the power, but when it comes in nothing compares to it
Old Nov 15, 2004 | 12:07 PM
Default Re: (HybridHatch88)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HybridHatch88 &raquo;</TD></TR><TR><TD CLASS="quote">
Turbo lag is way overblown, sure you have to wait a second for the power, but when it comes in nothing compares to it</TD></TR></TABLE>
couldn't have been said any better....bump for another boosted honda in tucson
nonvtecD's Avatar
Nice, welcome to the dark side
Old Nov 15, 2004 | 12:11 PM
JakeB.'s Avatar
Photography Pundit
interested in seeing a little review also
very sexy car
Old Nov 15, 2004 | 12:15 PM
AzG35's Avatar
Definately different type of power. NA, the car was super responsive and very linear. With this setup, there isn't a whole lot of lag, the reason I got a 50 trim instead of a 57 or 60. Basically, if I stomp it from a very slow roll, the turbo will start spooling around 2800, 5psi by 3200rpms, 6psi by 3500, 7psi by 4000. The car just rips the tires in 1st and 2nd. The car pulls hard in 3rd, actually haven't gotten into 4th yet. Overall a
I'm sure I'll have another NA car eventually though
Old Nov 15, 2004 | 12:19 PM
RobbieG35's Avatar
12 Years Strong
Default Re: (AzSi22)
So which do you like better?
Old Nov 15, 2004 | 12:22 PM
11psiTurboSI's Avatar
nice #'s
Old Nov 15, 2004 | 12:23 PM
AzG35's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HybridHatch88 &raquo;</TD></TR><TR><TD CLASS="quote">So which do you like better? </TD></TR></TABLE>
NA for simplicity
Boost for all out power and speed
