Is my theory CorrecT??
Old Feb 24, 2005 | 06:50 AM
m R g S r's Avatar
Default Is my theory CorrecT??
Alright, So ever since I got my car tuned by Jeff Evans, like two weeks after actually, it's been running like ****. I mean 10-15 miles per gallon, and hesitation at 0 load, or between vaccuum and boost. . .
I could never figure out what it was, until someone mentioned to me that something in my setup had to have "changed" since the tune. . . .They mentioned FPR etc. . .
I don't have a FP Gauge, but I will get one this week. Anywho, I was thinking REALLY hard as to something that changed. . .and it was a vaccuum leak that I had while we dyno'ed.......
There was like a tiny pinhole leak between one injector and the injector seal on the intake manifold. . .
So now for my theory. . .
I fixed that AFTER I got home from the dyno. I was thinking, that that hole was enough to lean out the car while Jeff was tuning it, and now that it's fixed, its running pig rich. . .(I mean black smoke at idle, fuel COVERES the rear bumper)
I think the really low idle and spitting tons of fuel is do to the fact thatr Jeff was trying to get it to idle normally, but couldn't because of the leak, so he richened it up all the way. . .
So, Basically I need to go back to him for a re-tune, correct? I figure, while I'm at it, I might as well throw on a thick HG and tune for more HP. . good idea?
Or am I totally wrong, and that is not the problem haha
Uberdata
DSM 450's
b16a, p30 pistons, GSR head
Walbro 255 pump
AEM fuel rail
Stock FPR
(rest in sig. . . )
Old Feb 24, 2005 | 06:57 AM
NJIN BUILDR's Avatar
Default Re: Is my theory CorrecT?? (m R g S r)
Your vacuum leak is only a vacuum leak at idle and before boost.After that its a boost leak and won't really affect the tune at boost and wot.I think you need to keep looking.
Glenn
Old Feb 24, 2005 | 07:04 AM
m R g S r's Avatar
Default Re: Is my theory CorrecT?? (NJIN BUILDR)
No, I meant its running realy rich and getting bad gas milage when I drive (partial throttle. . . )
WOT still pulls like a **** (well to others, my car feels slow to me cuz I drive it every day )
Old Feb 24, 2005 | 07:10 AM
SOHC_MShue's Avatar
yea it sounds to me like that hole was your problem. You should get a wideband so you can check these things and make adjustments to uber yourself.
Old Feb 24, 2005 | 07:20 AM
That's probably it then.Sounds like a good time to kill off some of that compression ratio.Do the head gasket.
Glenn
m R g S r's Avatar
Default Re: Is my theory CorrecT?? (SOHC_MShue)
I don't have a chip burner, laptop, or the knowledge to do so. .. lol
BTW, I have a cometic HG, I don't know if it lowers the compression thou. . .here's what it says on the package. .
It says .043" MLS, Nitrous and Turbo
Will that lower the compression? If not, anyone wanna buy it, I have no use for it
Old Feb 24, 2005 | 07:21 AM
g2turbo's Avatar
have you talked to Jeff?
Old Feb 24, 2005 | 07:22 AM
m R g S r's Avatar
Default Re: Is my theory CorrecT?? (g2turbo)
Yea, and he thought it was the 02 sensor going bad. . .He said he's only heard of it once and that was a while ago. . .
I did tell him I fixed the leak like right after I did, but that was months ago. . .
Old Feb 24, 2005 | 07:25 AM
Short Round's Avatar
where do u live? it'd suck to drive that far on a motor that's runnin like that
no one local to u w/ a wb u can borrow to see whats goin on?
Old Feb 24, 2005 | 07:30 AM
TurboJesse
Guest
Posts: n/a
Default Re: Is my theory CorrecT?? (Short Round)
I don't know if this has anything to do with it or not but on my car and a few other cars ive tuned with uberdata ive noticed that i'll tune the car to a soild high 13-low 14 a/f crusing and part throttle. Week or so later at the same load/rpm points and it will now be reading high 11's low 12s a/f..Its done this a few times and i just would reburn chips until it went away..
Old Feb 24, 2005 | 07:32 AM
SOHC_MShue's Avatar
you should just buy a chip burner and an old laptop. Chip burners can be had for like $50. An old laptop...maybe 2-300? I have gotten my afr very near perfect at every load/rpm and i can tell you I didn't know **** about tuning a year ago...it just takes a little practice. At the price you are paying to keep getting it tuned it may be better in the long run to just go ahead and get a burner.
Old Feb 24, 2005 | 07:33 AM
word
Old Feb 24, 2005 | 07:40 AM
VTC_CiViC's Avatar
Default Re: Is my theory CorrecT?? (Mpir3)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mpir3 &raquo;</TD></TR><TR><TD CLASS="quote">I don't know if this has anything to do with it or not but on my car and a few other cars ive tuned with uberdata ive noticed that i'll tune the car to a soild high 13-low 14 a/f crusing and part throttle. Week or so later at the same load/rpm points and it will now be reading high 11's low 12s a/f..Its done this a few times and i just would reburn chips until it went away..</TD></TR></TABLE>
Odd.. never happend to me, at least not on my cars when I'd left the WB attatched for days/weeks at a time..
Back to the original topic though, why not try simulating the original leak by pulling a small vacuum hose off and see if the car returns to it's former state. If it does it's an obvious answer to the problem, if not, you know the leak isn't/wasn't the issue.
Old Feb 24, 2005 | 07:46 AM
B18C1CYA's Avatar
sounds to me that the leak was the problem , when have jeff tune my car i make shure every thing is in order no leaks or any issues , just for this reason one small thing can change your tune , did you say you added a fpr to your setup ??
Old Feb 24, 2005 | 07:57 AM
PM-Performance's Avatar
Default Re: Is my theory CorrecT?? (B18C1CYA)
vac leak i dont think would cuase the prob unless it cuase the FP to change, but the fuel leak will have made the difference becuase it woulda been running lean in most cases.
Old Feb 24, 2005 | 07:58 AM
SOHC_MShue's Avatar
Default Re: Is my theory CorrecT?? (itr206)
yes it definintly sounds like a fuel leak issue. I have heard of people's cars running like complete **** just from the tinniest leak in an injector o-ring.
Old Feb 24, 2005 | 09:26 AM
m R g S r's Avatar
It wasn't a fuel leak. . .It was a leak between the injector seal on the intake manifold and the injector. . .
I just bought a FP gauge, I'm gonna put it on now. . .
And I went to an auto parts store to buy a new 02 sensor also, but they ****** quoted me $292!!!!
WTF?!?!?!
Nope, stock FPR since I got it tuned, and it's still stock now. . .
Old Feb 24, 2005 | 09:32 AM
if that injector seal is cracked it will leak fuel. Well at least you are mor probable to leak fuel then air. thats for sure.
ive seen it many times. trust me
Old Feb 24, 2005 | 09:51 AM
Muckman's Avatar
Moderator in Chief
put the leak back. easiest way to fix your problem
Old Feb 24, 2005 | 09:55 AM
Default Re: Is my theory CorrecT?? (Muckman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Muckman &raquo;</TD></TR><TR><TD CLASS="quote">put the leak back. easiest way to fix your problem </TD></TR></TABLE>
muckman is on a role today
Old Feb 24, 2005 | 10:01 AM
m R g S r's Avatar
Well it wasn't cracked at all. . . The injector was too far up in the fuel rail, and it wasn't seating properly in the seal on the IM. . .(it wasn't pushed in all the way)
BTW, Just put on the FP gauge. . . its at 48-50psi at idle with the vaccuum line connected. . .
Old Feb 24, 2005 | 11:46 AM
u should be on the phone w/ jeff as he tuned the car
Old Feb 24, 2005 | 12:11 PM
call him and see what he says. But if you had probs with the car, you shouldnt have taken it to get tuned until that was panned out.
Old Feb 24, 2005 | 12:17 PM
m R g S r's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by itr206 &raquo;</TD></TR><TR><TD CLASS="quote">call him and see what he says. But if you had probs with the car, you shouldnt have taken it to get tuned until that was panned out.</TD></TR></TABLE>
Didn't know there was a leak. . .Was reading 22 vaccuum at idle. . .perfect. . .Jeff didn't even find the leak either. . .
Old Feb 24, 2005 | 12:18 PM
m R g S r's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Muckman &raquo;</TD></TR><TR><TD CLASS="quote">put the leak back. easiest way to fix your problem </TD></TR></TABLE><TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Muckman &raquo;</TD></TR><TR><TD CLASS="quote">put the leak back. easiest way to fix your problem </TD></TR></TABLE>
See, I would. . .But it really fucked up the idle, It would bounce from 1k to like 4k with the IACV plugged in, and when I unplugged it, it sounded like a V8 with some nasty cams. . . .
