? on my spark plugs pics
Old Nov 18, 2005 | 09:27 AM
Silverhatch's Avatar
Default ? on my spark plugs pics
My setup is a 9.1 cr gsr motor. I havent put the turbo on it yet. my car started making a knocking noise today and i pulled the plugs can someone tell me what they think ? thanks danny
Old Nov 18, 2005 | 09:36 AM
beepy's Avatar
Default Re: ? on my spark plugs pics (Silverhatch)
Slight oil consumption, good AFR. Looks like maybe #2 had gotten loose and the ticking sound was high pressure gas getting past the threads? That would at least explain the discoloration on the nut portion.
Old Nov 18, 2005 | 09:40 AM
Default Re: ? on my spark plugs pics (beepy)
I put the plugs back in and its still making the same noise. I think its coming from the bottom end and its got 12000 na miles on it. im gonna have to pull the oil pan and see how things look
Old Nov 18, 2005 | 09:41 AM
Hybrid96EK's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Silverhatch &raquo;</TD></TR><TR><TD CLASS="quote">I put the plugs back in and its still making the same noise. I think its coming from the bottom end and its got 12000 na miles on it. im gonna have to pull the oil pan and see how things look
I would reccomend using a mechanics stethescope to listen for the source of the noise. You can get a pretty good idea using one where the noise is comming from. If you don't have one, a long screw driver or pry bar works also. Just wrap your hand over the end of the handle and stick your hear to it.
Old Nov 18, 2005 | 09:50 AM
flood's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by beepy &raquo;</TD></TR><TR><TD CLASS="quote"> Looks like maybe #2 had gotten loose and the ticking sound was high pressure gas getting past the threads? That would at least explain the discoloration on the nut portion.</TD></TR></TABLE>
yeah that discoloration doesn't look right
Old Nov 18, 2005 | 10:09 AM
Finland's Avatar
looks like #2 in the pic got hotter than hell for some reason.
Ritchie
Mar 23, 2011 02:52 AM
95dxsir2
Dec 30, 2010 08:07 AM
civycoop
Nov 2, 2007 11:17 PM
iixerOii
Jun 28, 2004 09:15 PM
