are my plugs too hot?
Old Apr 5, 2004 | 01:38 PM
Lei Siew Long's Avatar
Default are my plugs too hot?
I am running a set of NGK plugs with a heat range of 7, BCPR7ES are the actual plugs i'm running, and i have been driving the car hard to try to replicate the violent bogging problem i was having before.
well, i pulled the #3 plug and the color of the insulator is a yellowish color. i was looking through my Haynes manual, since the helms doesn't have a colored picture of the plugs, and it says the yellow color on the insulator is "high speed glazing." and this is caused by quick and abrupt acceleration (makes sense).
My questions are: is the yellowish color normal and should I change to a colder plug?
the color of the plug is pretty similar to this. not exact, but, similar.
Old Apr 5, 2004 | 02:09 PM
MaxSterling's Avatar
Default Re: are my plugs too hot? (Hatch4urSnatch)
go with the hottest plug that does not promote detonation. heat range 7 is good for most street applications
Old Apr 5, 2004 | 02:51 PM
asiangl2's Avatar
what is your setup and how much boost are you running... also what is your fuel managment???
Old Apr 5, 2004 | 03:59 PM
KiddEng's Avatar
Default Re: are my plugs too hot? (asiangl2)
i got this from a site about glazing of the insulator.
http://www.triplesonline.com/t...s.asp
"This condition may cause misfiring at high engine RPM. Shiny deposits usually suggest that temperatures have suddenly increased during hard acceleration. As a result, normal metallic deposits do not have a chance to slough off the plug and they melt and form a conductive coating which causes the misfire. Yellow or tan deposits, as shown below, usually indicate the use of leaded fuel."
the picture on the site match that pic.
running any leaded fuel? do they still sell leaded fuel at the pumps?
Old Apr 7, 2004 | 03:56 AM
Default Re: are my plugs too hot? (KiddEng)
thanks for everyone's posts. any other ideas?
Old Apr 7, 2004 | 04:18 AM
stackz's Avatar
at the jetties fishin'
Community Builder
I wouldn't worry about the discoloration of the ceramic too much. If the actual electrodes showed some sort of unusual wear or deposits or there were deposits on the ceramic or it was cracked...then I'd worry.
At worst, I'd say you're running a little lean.
Yngbld14
Apr 14, 2013 11:10 PM
2DoorBandit
Jan 30, 2007 02:53 PM
draco067
Aug 11, 2003 07:02 AM
93H22ACX
Mar 13, 2003 05:13 PM
RJL
Oct 27, 2001 11:44 AM
