my oil return
Old Nov 11, 2003 | 07:13 AM
arjusmc's Avatar
Default my oil return
just wanted to know if the experts thought this was ok. i've had two turbos smoke. one i believe was in need of a rebuild and the other was just of poor quality. i'm upgrading to either a precision or a t3to4e off of cheapturbo.com in a week or so. anyways is this the cause of the smoke or should i be fine once a put a quality turbo on.
update got the right pics up.
Modified by arjusmc at 4:27 PM 11/11/2003
Modified by arjusmc at 5:39 PM 11/11/2003
Old Nov 11, 2003 | 07:14 AM
HXMan's Avatar
Default Re: my oil return (arjusmc)
Would be nice to see a pic of it going into the oil pan.
Ri5e's Avatar
I'm having a hard time figuring out what's going on in those pictures
Old Nov 11, 2003 | 07:16 AM
hulkhb's Avatar
Default Re: my oil return (CRV Monster)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CRV Monster &raquo;</TD></TR><TR><TD CLASS="quote">I'm having a hard time figuring out what's going on in those pictures </TD></TR></TABLE>
arjusmc's Avatar
sorry posted wrong pics, let me fix it
Old Nov 11, 2003 | 07:50 AM
InTeGrA B18b1's Avatar
get a ss line.
Old Nov 11, 2003 | 08:01 AM
arjusmc's Avatar
Default Re: my oil return (InTeGrA B18b1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by InTeGrA B18b1 &raquo;</TD></TR><TR><TD CLASS="quote">get a ss line.</TD></TR></TABLE>
how does that have anything to do with the oil return line dipping to low?
Old Nov 11, 2003 | 08:26 AM
xjoe's Avatar
edit: take the orig.jpg out of your pics when you post em
Old Nov 11, 2003 | 08:30 AM
SuperTeg95's Avatar
yes. Your setup could cause oil to build up and make your car smoke. Your line levels out and needs to be a angled down from the turbo to the pan. Don't let it level out.
Old Nov 11, 2003 | 08:38 AM
arjusmc's Avatar
Default Re: my oil return (SuperTeg95)
can it cause smoke without damaging the turbo? or is the turbo gone for sure.
Old Nov 11, 2003 | 09:19 AM
Tinker219's Avatar
sometimes it just "seeps" past the seals without damaging them. BUt if you were getting BILLOWING smoke, than its probably gone.
&lt;----who has gone through 4 turbos this summer. I think they were all bad, because Ive had 1.25" ID return lines all summer, ALL downhill. One of the turbos developed a 1/4" lateral shaft play within 100 miles
Old Nov 11, 2003 | 10:17 AM
HXMan's Avatar
Yea, you will want to fix this. Upward sloping to the pan = Bad.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by arjusmc &raquo;</TD></TR><TR><TD CLASS="quote">
Modified by arjusmc at 5:39 PM 11/11/2003</TD></TR></TABLE>
Old Nov 11, 2003 | 10:25 AM
NotPhilTran's Avatar
Default Re: my oil return (HXMan)
what do you guys mean by the angle of the oil line? good vs bad? i dont want it straight and i dont want it angled? could some one clear the confusion on a good routed oil line?
Old Nov 11, 2003 | 10:40 AM
SuperTeg95's Avatar
Default Re: my oil return (stolencrx)
you want it to be as straight down as possible. ie: no kinks, or dips. Just down. The oil has to run down hill, not up hill.
Oil line should look like \
Old Nov 11, 2003 | 10:52 AM
sol2nr's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SuperTeg95 &raquo;</TD></TR><TR><TD CLASS="quote">you want it to be as straight down as possible. ie: no kinks, or dips. Just down. The oil has to run down hill, not up hill.
Oil line should look like \</TD></TR></TABLE>
yeah....
not like this: \_ and especially not like this:
l
\_/
Old Nov 11, 2003 | 11:47 AM
Default Re: my oil return (sol2nr)
thank ya.
Old Nov 11, 2003 | 01:29 PM
arjusmc's Avatar
so adding a 45* bend at the turbo should help out??
Old Nov 11, 2003 | 01:56 PM
rOby's Avatar
replace that hose when u do it too, use stainless. that rubber or wahtever is askn for trouble
hardparked_ehtwo
Jan 11, 2008 06:12 PM
xtremeness101
Jun 20, 2007 09:43 AM
ZC88CRX
16
Nov 14, 2003 01:28 PM
