my next project
Old Oct 31, 2005 | 05:41 PM
eggiel's Avatar
Default my next project
ok i will like to make my civic hb turbo but i need to know the best brand and what turbo size should i use also downpipes,manifold and other these are my motor specs tell me what i should change and what should i get
sleeved b18a1
strock 2.1 liter
cp pistons 12.1
crower billet rods
b16 head
ferrrea valves
toda spec d cams
skunk 2 intake
72mm erick racing throttle
maybe hondata s300
RC injectors 300cc
Old Oct 31, 2005 | 06:04 PM
LSVtechnologytur...'s Avatar
Default Re: my next project (eggiel)
Need to know power goals for the car.
If your building the whole motor chances are 300cc injectors will not be enough.
Old Oct 31, 2005 | 06:13 PM
B18 CYA's Avatar
pretty high compression you're wanting to run
Old Oct 31, 2005 | 06:29 PM
eggiel's Avatar
Default Re: (B18 CYA)
i know all these has to go but what shold i get
ok lets say i wold like at least 600hp
what do i need to achieve these goal
Old Oct 31, 2005 | 06:35 PM
B18 CYA's Avatar
look at peoples setups on here. theres lot sof them
Old Oct 31, 2005 | 06:42 PM
danthemang3's Avatar
if you want to take a b18a to a 2.1, why not sleeve and bore a b20?
eggiel's Avatar
oh thanks for the help iam reading
Old Oct 31, 2005 | 06:44 PM
HybridKOOP's Avatar
Default Re: (eggiel)
I highly recommend a 1.5L w/ carbs and a 250-shot dry nitrous setup.
Old Oct 31, 2005 | 06:46 PM
eggiel's Avatar
my block is already a 85 mm its strock to 2.1 liter i just need the turbo setup
Old Oct 31, 2005 | 07:29 PM
rhd's Avatar
rhd
haha
there's no way you'll pull 600whp out of your setup
your compression is too high for one thing...it'd make tuning a bitch
your rods are crap over 500whp, just look at all the threads lately
your injectors are WAY too small
your cams are just too big
you'd be much better off selling your supposed setup and just starting over. you don't need a stroker for turbo, stock stroke will work juts fine with mild goals like 600whp
Old Nov 1, 2005 | 03:08 AM
eggiel's Avatar
i dont think you know how to read i never said these is what i have to make my car turbo
I said these is what i have cause my car was natrully aspirated
and i ask what should i get rid off and what should i keep and what do i need to go turbo
this is not a post to laugh at its post to help
so next time you want to type in read carefully
Old Nov 1, 2005 | 04:01 PM
eggiel's Avatar
nobody
Old Nov 1, 2005 | 06:24 PM
bnut510's Avatar
lower the compression, get some bigger injectors, build up the head, and booooost
Old Nov 2, 2005 | 04:36 PM
eggiel's Avatar
what comression should be good and what piston brand
Old Nov 2, 2005 | 05:01 PM
karmadhi's Avatar
for 600whp you will run high boost, I would do a 8:1 or 8.5:1. Get some j&e and good to go.
Old Nov 3, 2005 | 03:21 AM
eggiel's Avatar
and what size of turbo and brand
Old Nov 4, 2005 | 10:52 AM
eggiel's Avatar
up
Old Nov 4, 2005 | 03:07 PM
N20civicB18's Avatar
you want CP pistons, JE's make to much noise... and you want the compresion ratio around 9.2:1, manly rods, stock crank.
Kyle
oh yeah your gonna need atleast 1000cc injectors
mando_eg2
Sep 3, 2013 08:12 AM
Hardrath_R
44
Jul 23, 2012 02:09 PM
andersonkid531
Oct 16, 2011 02:52 PM
crxb20vtec
Feb 9, 2011 02:22 PM
boostd ls
Sep 8, 2007 12:28 PM
