My modified Starion IC. Specs and pics inside......
Old Nov 28, 2001 | 07:17 PM
93LSivic's Avatar
Default My modified Starion IC. Specs and pics inside......
Ok since there's some people interested in these I took some pics.
Measurements are as follows:
Height: 8.5 inches
Depth: 2.75 inches
Core Width: 16.5 inches
End tank to End tank Width: 21.5 inches
I put in 2.25 in/outlet piping, this is the largest you can go without having new endtanks welded on.
As you can see I modified this IC. For those who dont know the original configuration had the piping (small 1.5") coming from the top.
I was quoted a price of $200 to have new piping welded (heli-arked) onto the sides. I said screw that and just JB welded them and the caps to cover the original in/outputs.
Hopefully this will be good until I decide to go with a larger intercooler.
Let me know if you have any questions.
This here shows the cap on the top covering the original in/outlet and a closer look of my JB weld job on the new in/out
Enjoy
Old Nov 28, 2001 | 07:55 PM
ForcedAccord's Avatar
Texas B*tch!
Default Re: My modified Starion IC. Specs and pics inside...... (93LSivic)
Wow, it looks REALLY good, nice job on the JB weld. Sometimes I tend to get carried away w/ that stuff, but anyways, where did you purchase this i/c? It looks like it's in excellent shape.
Old Nov 28, 2001 | 11:08 PM
Charles B.'s Avatar
Default Re: My modified Starion IC. Specs and pics inside...... (ForcedAccord)
Looks good Are you also going to make brackets to make it fit on your car? Do you know how much boost/horsepower you can run with it? It's a nice cheap intercooler that I also plan to use.
[Modified by SuperDuperEG, 8:10 AM 11/29/2001]
[Modified by SuperDuperEG, 8:12 AM 11/29/2001]
Old Nov 28, 2001 | 11:16 PM
Damon B.'s Avatar
Default Re: My modified Starion IC. Specs and pics inside...... (SuperDuperEG)
What is a jb weld?
Old Nov 28, 2001 | 11:57 PM
dbman96's Avatar
New User
Default Re: My modified Starion IC. Specs and pics inside...... (CleanSi)
Think "5-minute epoxy with steel dust mixed into it" but it's a lot stronger than it sounds. Bonds metal very well, can be ground, filed, sanded, etc. after it sets.
Old Nov 29, 2001 | 08:02 AM
SiR Kid's Avatar
New User
Default Re: My modified Starion IC. Specs and pics inside...... (dbman96)
JB weld is my bottomed out-leaky *** oil pan fixer upper
I've got a nice Gray bottomed oilpan at this time No leaks tho! ROFL!
Old Nov 29, 2001 | 08:25 AM
lucas569's Avatar
Default Re: My modified Starion IC. Specs and pics inside...... (SiR Kid)
duck tape and jb weld are the staples of life!
Old Nov 29, 2001 | 09:10 AM
zojirushi's Avatar
Default Re: My modified Starion IC. Specs and pics inside...... (lucas569)
Where can u buy this JB weld stuff? Home Depot?
u think it will hold together under the boost?
[Modified by zojirushi, 1:10 PM 11/29/2001]
Old Nov 29, 2001 | 09:16 AM
Texas B*tch!
Default Re: My modified Starion IC. Specs and pics inside...... (zojirushi)
Can it hold together under boost... bahahahah JB is the ****!!!!!!!! God's gift to man I swear, it kicks *** man. You should be able to get it at any home appliance store or your local auto shop might carry some as well. Just don't go crazy w/ that stuff, god I love you Mr.JBWELD
Old Nov 29, 2001 | 09:19 AM
zojirushi's Avatar
good stuff then ehehehe
Old Nov 29, 2001 | 09:21 AM
Texas B*tch!
Yeah man, it's definitely the ****, your first experience w/ it will be quite exhilerating.
Old Nov 29, 2001 | 09:22 AM
dbman96's Avatar
New User
I buy it at Kragen / Shucks / whatever the fsck auto parts store you have - buy it in the "Industro-Weld" package you get 5 times as much for 2 times the price of the little package. I believe the Industro-weld takes a little longer to set but it is stronger as well. I'm actually using JB-Quik on my BOV flange/riser tube and if you clean and sand both surfaces before application it holds up great. No problems at all.
Old Nov 29, 2001 | 09:59 AM
gtcali's Avatar
Whoa, I was gonna get mine welded to look like that (which is supposed to be expensive I hear). I never thouht of using JB weld. Did you use aluminum 2.25 pipes or steel? Pretty strong eh. I wa planning to shoot a light coat of flat blac over mine so I really don't care how the JB weld looks. Though your looks like a pretty clean job.
Old Nov 29, 2001 | 11:12 AM
BoostedED9's Avatar
YES!!!!!
Old Nov 29, 2001 | 11:28 AM
Jet Phi's Avatar
Default Re: My modified Starion IC. Specs and pics inside...... (ED9Hybrid)
wow that's really nice looking
Old Nov 29, 2001 | 01:42 PM
DLB1994's Avatar
Old Nov 29, 2001 | 02:59 PM
dbman96's Avatar
New User
Default Re: My modified Starion IC. Specs and pics inside...... (DLB1994)
nice thing about JB weld is it doesn't care what material you use; I've JB'd Al piping to steel pipe with great success
salival
Welding / Fabrication
14
Dec 6, 2010 07:51 AM
strongarm1731
Feb 25, 2006 04:26 PM
topspeed86
Jul 11, 2005 04:03 PM
pearlwhitecrx
Apr 23, 2005 03:54 PM
Hybrid
Apr 10, 2002 09:40 PM
