is my ecu fried
Old Aug 31, 2003 | 02:15 PM
extrmeboost's Avatar
Default is my ecu fried
the accessories come on but the car wont crank, the ecu makes a wierd clicking/humming noise when i turn the key, also the vafc is not coming on, all the fuses are good as well.
Old Aug 31, 2003 | 02:17 PM
VaporTrail's Avatar
New User
Default Re: is my ecu fried (extrmeboost)
check your main fuses under hood
is the fuel pump priming?
is there any codes the ecu is displaying?
Old Aug 31, 2003 | 02:19 PM
Default Re: is my ecu fried (VaporTrail)
no check engine light, all the fuses are good and the fuel pump whines as usual (holley 255lph)
Old Aug 31, 2003 | 02:21 PM
VaporTrail's Avatar
New User
check your battery voltage. If its all good, your starter is done stunna
Old Aug 31, 2003 | 02:27 PM
but what about the vafc not working, thats what worries me
Old Aug 31, 2003 | 02:40 PM
its a new battery so im not worried about that, any ideas?
Old Aug 31, 2003 | 05:10 PM
Joseph Davis's Avatar
The ECU makes a clicking/humming noise??
Something is frux there, buddy. It's all solid state components, nothing should make a peep. Pull the ECU covers and look... you probably have a bad connection that you can identify visually. There is a chance that if you find such a connection you can just reflow the solder joint + problem fixed.
jamclaur
Jul 21, 2005 09:04 AM
bub838
Apr 22, 2004 08:03 PM
lude97dude
Jan 26, 2003 10:14 AM
hybridbmw
Jan 8, 2003 11:15 PM
MikeySpec
Sep 12, 2001 02:23 PM
