my build up
Old Aug 12, 2007 | 07:37 AM
  #26
dbiker207's Avatar
Default Re: (Sr420Det)
Old Aug 12, 2007 | 08:53 AM
  #27
jchrm80's Avatar
looks awesome man, good job and good luck with it.
Old Aug 13, 2007 | 07:35 AM
  #28
dbiker207's Avatar
Default Re: (jchrm80)
finally off the engine stand
Old Aug 13, 2007 | 10:17 PM
  #29
dbiker207's Avatar
Default Re: my build up (dbiker207)
its in the car!!
Old Aug 14, 2007 | 01:31 PM
  #30
PiMpIn's Avatar
cant wait were gettin so close, its gonna be nasty!!!
Old Aug 14, 2007 | 04:41 PM
  #31
CO_CReX's Avatar
Wow this is a great build thread!
I can't wait to see it finished!!
subscribed
Old Sep 20, 2007 | 07:27 PM
  #32
Ch3mik's Avatar
Default Re: (CO_CReX)
what u usin for the hydro to cable conversion
Old Sep 21, 2007 | 05:02 AM
  #33
dbiker207's Avatar
Default Re: (Ch3mik)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ch3mik &raquo;</TD></TR><TR><TD CLASS="quote">what u usin for the hydro to cable conversion
hasport conversion kit
Old Sep 21, 2007 | 08:33 AM
  #34
JDMCRX's Avatar
Default Re: (dbiker207)
Nice work should make some good power
Old Oct 8, 2007 | 09:35 PM
  #35
dbiker207's Avatar
Default Re: (JDMCRX)
finaly got around to taking more pics. its pretty much done and i have a tuning apointment on 10/18. i will post up the results.
Old Oct 10, 2007 | 10:46 AM
  #36
PiMpIn's Avatar
cant wait to see it rip
Old Oct 10, 2007 | 10:59 AM
  #37
Snafubmx234's Avatar
Logs FTW!
Looks really good.
Old Oct 15, 2007 | 05:04 AM
  #38
PiMpIn's Avatar
Default Re: (Snafubmx234)
Tuning in 3 days cant wait for thursday
Old Oct 15, 2007 | 05:26 AM
  #39
boostismycrack's Avatar
E-thug
Default Re: (PiMpIn)
Looks good man, hope u have better luck with your rs machine block than i did. My sleeves sank and caused me alot of headaches, keep an eye on your coolant temps...
Old Oct 15, 2007 | 06:54 AM
  #40
dbiker207's Avatar
Default Re: (boostismycrack)
were they willing to fix the problem?
Old Oct 17, 2007 | 06:07 PM
  #41
PiMpIn's Avatar
tomarrow is the day
Old Oct 17, 2007 | 06:09 PM
  #42
boostincoupe's Avatar
From: Destroying turbo ITR motors in Minneapolis, MN, U.S.A.
Baller motor, boring manifold
Old Oct 23, 2007 | 04:31 AM
  #43
PiMpIn's Avatar
Default Re: (boostincoupe)
quick post before were off to the tuning session at 10 hopefully today well make some power.
Old Oct 24, 2007 | 08:31 PM
  #44
dbiker207's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boostincoupe &raquo;</TD></TR><TR><TD CLASS="quote">Baller motor, boring manifold </TD></TR></TABLE>
the car only made 200whp, it has been narrowed down to the exhaust manifold being to restrictive. we tried everything else and it was hitting a brick wall at 200whp mark. gonna put a rams horn on it and see.
i also have some issues with cooling. the radiator i was using didnt keep up at all, so i bought a mishimoto and it barely keeps up in 55 degree weather. i guess im gonna have to figure somthing out before it gets warm out next season.
Old Oct 24, 2007 | 08:34 PM
  #45
dbiker207's Avatar
a/f ratio was cleaned up on the street after this pull
Old Oct 25, 2007 | 12:38 AM
  #46
90dxhmt's Avatar
Nice build the rex is clean and really solid looking setup you got there.The motor running good other then the 200whp issue?Should make some good numbers once you get it dialed in
Old Oct 25, 2007 | 06:41 AM
  #47
dbiker207's Avatar
Default Re: (90dxhmt)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 90dxhmt &raquo;</TD></TR><TR><TD CLASS="quote">Nice build the rex is clean and really solid looking setup you got there.The motor running good other then the 200whp issue?Should make some good numbers once you get it dialed in </TD></TR></TABLE>
yes the engine runs really strong other than the 200hp wall.
Modified by dbiker207 at 8:37 AM 10/25/2007
Old Oct 25, 2007 | 07:36 AM
  #48
SOHCD16y8's Avatar
Looking good!!!
Old Oct 25, 2007 | 10:31 AM
  #49
tokesGTR's Avatar
Default Re: (SOHCD16y8)
So you ran smaller B16 cams that will make less power than virtually any other B-series cam, for the sake of having more cam gear adjustment? That doesn't make a lot of sense to me. And you spent money on an eagle crank that you absolutely didn't need, but cheaped out on an intake manifold, and good exhaust manifold? Oy vey.
Old Oct 25, 2007 | 05:26 PM
  #50
JoePSI's Avatar
Default Re: (tokesGTR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tokesGTR &raquo;</TD></TR><TR><TD CLASS="quote">So you ran smaller B16 cams that will make less power than virtually any other B-series cam, for the sake of having more cam gear adjustment? That doesn't make a lot of sense to me. And you spent money on an eagle crank that you absolutely didn't need, but cheaped out on an intake manifold, and good exhaust manifold? Oy vey.</TD></TR></TABLE>
I also see that odd.. what I really cant grasp is the exhaust manifold holding you back that much. I have two friends who made ~350 on a drag log and 526whp 362tq on an inline pro log ( it can be found here http://masetuning.com/case.html ). I think your issue is elsewhere.
