Is my B16 head ready for boost? Help with identification
Old Jun 1, 2011 | 06:53 PM
BDogggUT34's Avatar
Default Is my B16 head ready for boost? Help with identification
So i picked up what i thought was a stock PR3-1 B16 head for a great price. Opened it up to build it, and found the first thing, 96+ GSR cams. So a plus....
I'm not too familiar with the valvetrain and what it looks like stock so......can anyone tell me if these are stock B16 or GSR valves? They look pretty decent, you think i could just clean these up and reuse these? On a side note, the valve springs had Dual springs intake marked green and single exhaust marked white.
Also, take a look at the ports, is this what a normal B16 head looks like or has this been ported? Also where the valve seals, has this had a valve job or does this look stock?
Trying to figure out if I should order Supertech valves, springs, retainers or if I can reuse what i have. This will eventually be on a built B18b bottom end. Looking for 400whp.
Old Jun 1, 2011 | 06:56 PM
the white sam's Avatar
Default Re: Is my B16 head ready for boost? Help with identification
am thinking mild port and polish?
Old Jun 2, 2011 | 03:56 AM
BDogggUT34's Avatar
Also, is that a 3 angle valve job or do the stock seats look like that with the color difference? I just dont know.....
Old Jun 2, 2011 | 05:04 AM
kyden's Avatar
your valves look ok to reuse. b16/gsr doesn't matter, they're the same. only ones that are different are type r.
Old Jun 2, 2011 | 11:06 AM
th3pwn3r's Avatar
Supertech valves, springs and retainers would be a good idea if you have the money to spare. If you're not revving that high you should be alright with your stock setup as far as I know. The idea of upgrading is to combat valve float which is more likely to happen the higher you rev your engine.
Old Jun 2, 2011 | 12:17 PM
civickiller's Avatar
the head looks stock other than the cams.Plenty people put gsr cams in a stock b16 head
92bseries
Apr 21, 2011 08:28 AM
tobster
Mar 26, 2011 03:25 PM
love4dirt
Dec 30, 2010 08:19 AM
X2BOARD
Nov 4, 2002 08:32 AM
