Is my B16 head ready for boost? Help with identification
So i picked up what i thought was a stock PR3-1 B16 head for a great price. Opened it up to build it, and found the first thing, 96+ GSR cams. So a plus....
I'm not too familiar with the valvetrain and what it looks like stock so......can anyone tell me if these are stock B16 or GSR valves? They look pretty decent, you think i could just clean these up and reuse these? On a side note, the valve springs had Dual springs intake marked green and single exhaust marked white. Also, take a look at the ports, is this what a normal B16 head looks like or has this been ported? Also where the valve seals, has this had a valve job or does this look stock? Trying to figure out if I should order Supertech valves, springs, retainers or if I can reuse what i have. This will eventually be on a built B18b bottom end. Looking for 400whp. http://i584.photobucket.com/albums/s...p/IMG_3882.jpg http://i584.photobucket.com/albums/s...p/IMG_3883.jpg http://i584.photobucket.com/albums/s...p/IMG_3884.jpg http://i584.photobucket.com/albums/s...p/IMG_3885.jpg http://i584.photobucket.com/albums/s...p/IMG_3888.jpg http://i584.photobucket.com/albums/s...p/IMG_3890.jpg http://i584.photobucket.com/albums/s...p/IMG_3892.jpg |
Re: Is my B16 head ready for boost? Help with identification
am thinking mild port and polish?
Also, is that a 3 angle valve job or do the stock seats look like that with the color difference? I just dont know.....
your valves look ok to reuse. b16/gsr doesn't matter, they're the same. only ones that are different are type r.
Originally Posted by BDogggUT34
(Post 45384114)
Trying to figure out if I should order Supertech valves, springs, retainers or if I can reuse what i have. This will eventually be on a built B18b bottom end. Looking for 400whp. |
the head looks stock other than the cams.Plenty people put gsr cams in a stock b16 head
