MSD Pro Billet Users How do you Like it? Are the Bugs fixed?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tony the Tiger »</TD></TR><TR><TD CLASS="quote">
I already thread locked the rotor screw, although mine never came loose or any signs of coming loose when I had it in the car for a few months. You should search for one of my early MSD Pro billet threads which contains lots of into from other members with quite a number of guys running into a number of problems... There are procedures you should take while installing the dizzy (basically checking for loose screws)
My stock ignition worked okay at 9500 RPM level, but once I shoved to 5th gear, the stock dizzy didn't like the overdriven load when approaching 160-170 mph. I also had to keep all OEM components (coil, ignitor, rotor) absolutely mint. After one oil change, the car will start lightly misfiring as usual, indicating a "tune up needed"..lol 10.5:1 CR, ITB's and water injection needs quite a bit of spark to keep up.</TD></TR></TABLE>i fixed all of the known problems before i put it on the car even with loctite from the start the rotor cam loose i run an mw ign box so i dont use a msd coil or there ignitor deal
i had the rotor problem too, just loctited and was good to go....
never had an issue with replacement parts....always got from Jegs/Summit in no time
seen 10.5k shifting, and have seen 40+lbs without misfires, and thats with a 6al and blaster coil lol-all changed now
I cant say much for the Coil drivers though, thats why i got rid of my driver but am still using the distributer.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vtekthis »</TD></TR><TR><TD CLASS="quote">i had the rotor problem too, just loctited and was good to go....
I cant say much for the Coil drivers though, thats why i got rid of my driver but am still using the distributer.</TD></TR></TABLE>
so what are you using for the coil driver?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by melovesboost »</TD></TR><TR><TD CLASS="quote">
so what are you using for the coil driver?</TD></TR></TABLE>
the AEM box
the AEM box
I am on my second distributor now, my 1st one only lasted 100 miles. The rotor actually catapulted through the cap, also taking out my vtec oil pressure switch
MSD replaced the dizzy with no questions asked, and like everyone else I pulled the new one apart and put locktite on all of the exposed bolts underneath the cap (2 rotor screws and also did the allen head cap screws)
Had this distributor on for over a year and a half and 3000 miles, no problems now.
siavosh
28
Mar 30, 2010 12:08 AM
Doug684
18
Jan 11, 2004 03:28 PM
slooogsr
Jul 5, 2003 08:55 PM
