Msd plugs wires?
I've searched about these "big" red wires on the forum and didn't find threads about
I m using some 20 years old OEM at the moment do you advise NGK (blue) or Msd? Because a friend give me a black Msd cap with the MSD plugs wires.
Who is Mr Robot?
I've used NGK blues on my d16 without issues, I use the big red MSD's on my LS/VTEC. Bigger plug wires offer less resistance and allow more current to reach the plug... making for a more powerful and efficient ignition system. Over time wires break down, especially if they are 20 years old... it would be a good idea to upgrade, especially if you're making decent power on a stock ignition system... you'll notice a smoother running car and more mpg when not driving like an *** lol. As well as a touch more power if your wires are that old.
I have NGK blues on my b16. They work just fine. Unless you are pushing some serious power, stock or the NGK. I always put bigger wires on my V8's but it seems like the consensus for the honda world is that it doesn't make a big enough difference to even matter about the size, just that they are newer and are a good brand name (NGK, Honda OEM, MSD). Find the best deal and go with it. Advice though, don't do the msd cap and external coil. Been down that road. Doesn't work as well on Honda's as it does on domestics. Honda ignition system is great as is IMO.
Who is Mr Robot?
Yea, external coil can cause a lot of issues, stock ignition system is stronger than you think
The only time I would modify anything is when going coil on plug for high power levels.
If funs are tight and your not running an EMS that will support COp or you dont want to fork out tons of money for hondata COP if your running hondata then there are alternatives. 650 can happen on stock ignition but it wont hold up.
I've been running a system Theshodan recomended for 5 years now without a hiccup. Summit digital cdi ignition box, crane ps92 coil and ignitor bypass box that i make or others make as well. the whole setup will run you about 275 bucks and will give you a lot more spark, better burn of the a/f mixture which in turn creates more torque overall.
Im running 27 pounds of boost with a plugs gap of .025. on stock ignition you would be more like a plug gap of .010
OEM NGK wires are where its at, there inexpensive and are proven to work great. All these aftermarket wires are hype mainly and the construction is usually crap. MSD wires are knock to pull apart from my experience. I have accel on my car currently just because they were left over from my old drag car and they work fine but i wouldnt buy them again the top of the boost keep coming off. PITA
magnecor are the way to go if your looking for an upgrade, otherwise, NGK blues are the way to go for a cheap good replacement set. MSD wires in my opinion are absolute junk, had a set and they fell apart after a couple thousand miles, and they use a proprietary cap for the distributor so you can use them on anything else.
I have had a few sets of different plug wires through the years and never had a set of plug wires other than Vato-Zones fall apart. If your using silicone and pulling at the appropriate location I'm not sure how you would experience this with any decent wire.
I was using them on my new motor..
Proprietary cap? On their Billet Distributor? I believe they do have a cap that has the back shell but its not necessary.
I have the MSD cap that your talking about. Its takes special wire ends that lock on which is nice not just push in and hang there loose. You can buy the ends and replace the ends on any spark plug wire. This is how mine is now and im buying NGK wires to replace my old accel's and getting new MSD cap that comes with the replacement ends to change them out on the ngk's.
Yes I use Hondata S300.
I use NGK at the moment with Oem distributor and I m going to use Msd cap, digital 6A and SS blaster coil. I tried the NGK wires on Msd cap and it matches no problem
From personal experience theyre junk. they have less spark energy that a stock coil. the blaster ss coil didnt last to long either maybe a year. i was running a .022 gap on stock coil and had to gap down to .018 with the blasster ss coil. i guess i should have been more specific to say blaster ss coils and blaster 2 coils. the blaster hvc coils are good.
From: 99 probs but a stolen car aint 1, ca, cerritos/fullerton
dam. I just picked up a couple of these for a good price.
http://www.msdignition.com/Products/...r_SS_Coil.aspx
are they really that bad? Just till I switch to cop?
Yes they really are crap coils. The blast 2 will last a long time but there nothign special and yes they work but again not a great performance coil IMO.
Maybe on paper there great compared to others and stock but im speaking from personal experience with them and they fail and have no spark energy compared to others. This is my experience. Im currently running a summit cdi box with crane ps92 coil and ignitor bypass and love my system. larger plug gaps give a better burn
