is msd mod cap and coil worth it??
Old Nov 10, 2005 | 09:49 AM
jsnm's Avatar
Default is msd mod cap and coil worth it??
is a modified msd cap and blaster ss coil worth it on a fully built turbo car? no aftermarket ignition is on it either.
Old Nov 10, 2005 | 10:04 AM
djnikko's Avatar
Default Re: is msd mod cap and coil worth it?? (jsnm)
If you've added more air and more fuel then it cant hurt to upgrade the spark, these 3 components are what make up the fire triangle. If everythings running great add it. If your having running issues then get them sorted before adding otherwise faults tend to build up on top of each other. I found this out myself.
Old Nov 10, 2005 | 10:16 AM
jsnm's Avatar
thanks for the opinion
Old Nov 10, 2005 | 10:18 AM
93turbo16's Avatar
I like stock ignition personally.
Old Nov 10, 2005 | 10:27 AM
djnikko's Avatar
Default Re: (93turbo16)
I cant remember whether you can upgrade just the coil I know this is a weak point on most honda's? I imagine MSD ignition may remove the need to carry a spare dissy round all the time
Old Nov 10, 2005 | 10:39 AM
93turbo16's Avatar
You can upgrade an run just an external coil.
Neesmo31
Jan 13, 2009 10:38 PM
budget
Apr 17, 2005 09:17 PM
gutted-dx
Aug 21, 2004 08:15 AM
_oemek_
Aug 16, 2004 04:16 PM
marques4130
May 9, 2003 06:24 PM
