MSD Issues.... Part number for coil wire
Old May 23, 2007 | 04:40 PM
PrecisionH23a's Avatar
Default MSD Issues.... Part number for coil wire
I've got a set-up I'm working on and it's using part number 84039 and has a janky little conversion to use their plug wire, aka 'Coil Power Tower Adapter.'
On a H series dizzy cap the screw does not sit far enough back to make 100% contact with the terminal. One way to fix it would be to cut the cap but then the plastic msd part would not fit snug. Another way would be to purchase a longer screw but again the plastic part will not go far enough into the housing to hold the screw and wire mesh in place.
So I was wondering if you guys knew the MSD part number for a msd wire that has one end as shown in the above picture but the other end that would plug directly into a OEM Honda distributor cap (male distributor terminal end, female coil plug end). I had a few of these wires before but I cannot find the part number anywhere and I can't find them in any of our catalogues. I've even been on summit racing trying to find the damn thing.
Thanks
Old May 23, 2007 | 04:54 PM
Default Re: MSD Issues.... Part number for coil wire (PrecisionH23a)
I found a picture of the coil plug that I used before if that helps anyone out
Old May 23, 2007 | 04:57 PM
tony1's Avatar
I've got some here if you need one.
Old May 24, 2007 | 04:06 AM
BoostedH23a1's Avatar
I make all my coil wires.
Old May 24, 2007 | 05:46 AM
Default Re: MSD Issues.... Part number for coil wire (tony1)
This is the part that is used... you simply crimp it on. MSD-3331
It's wierd because the last 2 set-ups that I did came with the wire pre-assembled. Anyways, that's the solution. Thanks tony.
Old May 24, 2007 | 06:57 AM
ladysman's Avatar
looks like TOny has you covered but I have one as well. IM me if you need it for some reason.
Old May 24, 2007 | 07:07 AM
Default Re: MSD Issues.... Part number for coil wire (ladysman)
A local parts store had them in stock luckily... so I snagged all 3 of them, haha.
lewzor
Jan 25, 2017 05:10 PM
piggypen
Feb 12, 2005 04:13 PM
integra-modder
May 16, 2004 12:07 PM
WeaponR
Apr 4, 2004 09:44 PM
DANG YO
Nov 21, 2003 09:40 PM
