MSD ignition problem?
Old Jun 6, 2007 | 12:47 PM
Eg4-TuRbO's Avatar
Default MSD ignition problem?
I had a new mechanic change my distributor and he never re-connected the red wire. I cant get into contact with my old mechanic, the one that did the work on my car, so now, my car spudders, overheats, and doesnt have the kick as it use to.
Is it the MSD that is causing this problem? if so, can someone tell me what to do...
thanks! HELP!
Old Jun 6, 2007 | 01:03 PM
A.E Motoring's Avatar
Default Re: MSD ignition problem? (Eg4-TuRbO)
put your ignition back to stock, see if it goes away
Old Jun 6, 2007 | 01:11 PM
Boostfed's Avatar
New User
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Eg4-TuRbO &raquo;</TD></TR><TR><TD CLASS="quote">I had a new mechanic change my distributor and he never re-connected the red wire. I cant get into contact with my old mechanic, the one that did the work on my car, so now, my car spudders, overheats, and doesnt have the kick as it use to.
thanks! HELP!</TD></TR></TABLE>
You can bypasss the MSD, you will need to take the black and orange wire from the msd to the coil off and have the wires inside the distributor for ground and positive go to the coil.
Old Jun 8, 2007 | 01:06 PM
Eg4-TuRbO's Avatar
Default Re: MSD ignition problem? (Boostfed.com)
i'll try that today...thanks
mikeedge
Mar 23, 2008 06:12 PM
deftones0817
Jun 20, 2005 06:59 AM
systemflits
Jul 29, 2004 03:22 PM
uneekcrx
Apr 11, 2002 09:05 PM
