Which MSD ignition for nitrous?
Old Jun 5, 2002 | 02:51 PM
dvp95's Avatar
Default Which MSD ignition for nitrous?
96 accord with 98 h22a and right now a small 35hp shot. Will go up to 50hp, then 75hp for the track. Which ignition system do you recommend for nitrous? 6A, 6AL, 6BTM(believe this is useful only for boost), or the 6 digital plus (has retarding ability. Also, how do I know how much to retard the timing?
Thanks
Old Jun 5, 2002 | 03:00 PM
PM-Performance's Avatar
Default Re: Which MSD ignition for nitrous? (dvp95)
i have the dig 6 = and its great i reccoment it for nos.
it has the boost retard that you preset. 2 degrees for every 50 hp is rule of thumb. i have mine at 2 degrees for 80 shot
plus it has the 2 step rev limit for lauching and for high end limit . . . its sweeet.
Old Jun 5, 2002 | 03:02 PM
dvp95's Avatar
Default Re: Which MSD ignition for nitrous? (itr206)
I was thinking of the dig 6 plus too. Where is the cheapest place to get this? Cheapest ive found is like 350. Was it hard to install? Thanks again
Old Jun 5, 2002 | 10:18 PM
Dutchie's Avatar
I paid about $300 Canadian for mine I think. It was pretty easy to install, I got the cap and coil as well. I would recommend mounting it in the passenger department because I had overheating problems with mine when I had it mounted on the strut bar.
Old Jun 5, 2002 | 10:29 PM
MugenSi00's Avatar
digital 6 is the only way to go! I bought one when I was running NOS and it carries over well with a turbo setup also. I got mine from summit racing.
Old Jun 5, 2002 | 10:33 PM
b18tdelsol's Avatar
Default Re: Which MSD ignition for nitrous? (MugenSi00)
Get a Jacob's Mastermind while ur at it.. and just run a msd sci..thats what i did when i had direct port
Old Jun 6, 2002 | 06:11 AM
Default Re: Which MSD ignition for nitrous? (b18tdelsol)
i have mine moun ted under the pass seat. . i had no room in the engine bay.
Old Jun 6, 2002 | 07:08 AM
dvp95's Avatar
just curious, but what wires do you have to connect to the ignition box? Im going to get mine today from summitracing for like $287 shipped. Not bad, but is there anything else you recommend like the blaster or coil.....etc....or is that not needed at this point?
Old Jun 6, 2002 | 07:23 AM
dvp95's Avatar
which blaster coil should I get? There is the blaster 2 and blaster 3. Whats the diff besides a few bucks. I would guyss the blaster 2 is for me, but not sure. Should I be getting a new distributor cover too? I just want to get everything at once and get this done with.
Old Jun 6, 2002 | 07:30 AM
X2BOARD's Avatar
I am not sure, but the blaster 3 shure is purdy.... And I got it cheaper than my blaster 2. Summit has a good price on 'em.
Old Jun 6, 2002 | 07:33 AM
Dutchie's Avatar
Just get the blaster 2. You don't have to get the cap, but it makes the install easier. You should get a new rotor while you're at it, they are cheap. The wires you connect the box to are inside the distributer, they are connected to the stock coil. The box also has two wires that connect to the battery and two that connect to the coil. You have to drill a hole in the distributer to connect two of the wires. Make sure you use silicone sealent on the hole when you are done.
Old Jun 6, 2002 | 07:51 AM
dvp95's Avatar
Default Re: Which MSD ignition for nitrous? (Dutchie)
so where does the blaster coil mount? Also, are you using your stock coil anymore when you install these coils? Does it replace the stock coil, or work in addition to it? Thanks again.
Old Jun 6, 2002 | 08:11 AM
redlinegsr's Avatar
digi 6 all the way....excellent tuning factors
Old Jun 6, 2002 | 08:24 AM
Default Re: Which MSD ignition for nitrous? (redlinegsr)
get the blaster ss coil, that was recommended the best coil for the dig 6 from msd techs direct, i called them cuz i couldnt make up my mind.
i got that dig 6 , the cap , the blaster ss , and the msd wires all at the saem time .
Old Jun 6, 2002 | 09:39 AM
Dutchie's Avatar
You can mount the coil somewhere in the engine bay, its uo to you. The stock coil inside the distributer is no longer needed so you can take it out.
Old Jun 6, 2002 | 09:58 AM
i have my coil mounted in front of my abs unit . . . that was the only place i had close to enough space.
MARVNVRAM
Oct 2, 2007 03:53 AM
gotalcoholmanup4
Aug 24, 2005 05:38 PM
p1ccoloz
Mar 9, 2003 04:18 PM
dvp95
Jun 5, 2002 11:24 PM
CanadaCivicSIR
Jan 30, 2002 05:47 AM
