Mounting Intercooler on JDM front DC2?
Old May 5, 2017 | 12:56 PM
carguy0316's Avatar
Default Mounting Intercooler on JDM front DC2?
Was hoping some one could post pics of how they mounted their intercoolers on DC2 ? I have some ideas but just wanted to see how others have done theirs.
Thanks
Old May 5, 2017 | 02:09 PM
TheShodan's Avatar
Moderator
Default Re: Mounting Intercooler on JDM front DC2?
No different than anyone else. It's based upon your exhaust manifold configuration. Once that's done, you then can start configuring the intercooler piping to work with the intercooler.
Please check some JDM front end setups with intercoolers. There are tons all over the forums here, including this one.
https://honda-tech.com/forums/forced...-goal-3231901/
Or, start with photos of your car with your exhaust manifold configuration, and you can get assistance from there.
Old May 5, 2017 | 03:41 PM
carguy0316's Avatar
Well I'm using a Sheepey Top mount kit with single back door intercooler on my Dc2R. I do not have a front bumper support and only the thin bumper mounting bar in there. It seems like I can probably fab something up but was looking to see how others have theirs hanging to gather some ideas. Ill take some pics if need be.
Thanks
Old May 6, 2017 | 05:23 AM
TheShodan's Avatar
Moderator
Thanks
Most don't bothermaking a full beam depending upon the size intercooler. The larger yours is, the less you need. End tanks can have tap points on the ends so that you can make brackets from part of the lower portion of the radiator support to hold there, or just simply use the i/c piping.
if you're using a top mount than it should be for larger turbos for drag racing anyway, so that gives you a lot of room to work with.
Old May 6, 2017 | 06:50 AM
carguy0316's Avatar
Yes I'm using a BW 8374 1.05 t4 twin scroll. The sheepey intercooler has the Female threads in the top of the unit to be mounted from above which makes it a bit trickier. Here is a link to the intercooler I have.
https://sheepeybuilt.com/collections...iant=919812725
Old May 6, 2017 | 08:08 AM
TheShodan's Avatar
Moderator
so you'll need to get a little creative and drill tap at the bottom to mount brackets there, or possibly weld two aluminum brackets at the bottom of the core, then drill and tap at the bottom of the radiator support, and bolt it there.
Old May 7, 2017 | 12:01 PM
carguy0316's Avatar
I may look into welding some brackets thanks Shodan. Also looking to wire power to my Hondata 4port and was wondering if I could tap into ECU pin A25 for power? Since I have to run to A11 for the signal
Old May 7, 2017 | 01:28 PM
TheShodan's Avatar
Moderator
I'm sorry, but I can't help in that area. I don't utilize MAC solenoids, nor have I touched a Hondata or modified OBD1 stock ECU since 2004.
Old May 8, 2017 | 12:12 AM
2kdrift's Avatar
the signal from the ECU is a negative power output, the other lead goes to switched positive usually tap into something near fuse box.
Old May 8, 2017 | 10:36 AM
carguy0316's Avatar
ok cool thanks, Well I thought a25 on the ecu was its power source so debated tapping that. Any suggestions on where to tap near fuse box?
codenamezero
Sep 6, 2011 03:44 PM
turbodailydan
Mar 20, 2010 08:04 PM
jdm-gsr
Jul 12, 2009 08:54 AM
Chee_dog
Sep 5, 2007 06:48 PM
Chee_dog
Sep 1, 2007 10:19 PM
