mounting fmic with molded bumper???
Old Aug 15, 2009 | 09:57 AM
vw eater's Avatar
Default mounting fmic with molded bumper???
hello i have a 91 crx si and i got a turbo kit from a buddy and was wondering if it is impossible to mount the fmic if the car is molded and unable to take off the bumper? should i just not run a fmic and run low boost? thanks for the help
Old Aug 15, 2009 | 11:30 AM
boostB4beauty's Avatar
Default Re: mounting fmic with molded bumper???
whatever you do, don't run without it....seriously, you will regret it.
you may need to just be creative and build some sort of bracketry to make it work.
or take it to a performance shop who might be able to help you.
Or post some underhood pics and see what people say...
Old Aug 15, 2009 | 01:04 PM
Poootie's Avatar
Topmount? lol
Or do like some of the VW guys and go WATER-AIR.
Old Aug 15, 2009 | 02:27 PM
srmofo's Avatar
honestly in a situation like that a water-2-air is the way to go....the prices have come down dramatically in the past few years and you can pick one up for about the same cost as a quality air-2-air. Or you can pick one up the drag FS thread for cheaper. Plus they take up less room and are versatile in the places you can mount them
Old Aug 15, 2009 | 06:23 PM
Autoworks's Avatar
Get a sawzall and an angle grinder and go to town. Get the front bumper off, don't mold it back on. You'd have to trim the backside of that bumper quite a bit to get the FMIC to clear anyway even if it wasn't molded on.
Old Aug 15, 2009 | 07:27 PM
jhammond_82's Avatar
Reject Papi
idk, unbolt it and the fenders to take it off as one piece? what happened if he had to take it off for some reason? plan ahead mabye? idk, lol.
Old Aug 15, 2009 | 11:28 PM
vw eater's Avatar
its all one piece i cant take it off, but i will get some pics of the engine and see what you think
Old Aug 17, 2009 | 04:29 PM
vw eater's Avatar
any other ideas?
Old Aug 17, 2009 | 04:47 PM
srmofo's Avatar
yoiu only have 3 options
A) cut the **** out of the bumper so you can attempt to mount it
B) remove all the molded ****, which from the sounds of it, isnt exactly the "look" you're going for
C) Water 2 Air intercooler.....those work better anyways, effiecency is the key to more power when turbocharging a car
Old Aug 17, 2009 | 07:00 PM
thehatchninja's Avatar
frozenboost.com has some good deals on air to water intercoolers, that's your only reasonable option.
Old Aug 17, 2009 | 07:29 PM
Jdmsoles's Avatar
From: Dodgin Cops all Round Ana-Crime to Orange & Sd
damn dude why does everything have to be molded you should of just added pieces to make everything line up beyond perfect. water 2 air :thumbup is the solution.
Old Aug 17, 2009 | 07:36 PM
redflaredcrx90's Avatar
why dont you try a dsm side mount i have the sam kit on my crx 90 si i have posted it a few time on here
Old Aug 31, 2009 | 07:43 AM
vw eater's Avatar
well i am about to get a new motor next week and was woundering if it was a good idea to boost the new motor or just keep it all motor becuse of the compression?its a lsvtec
- Ported DPR B16a head
- B18A1 block w/ .25 oversized USDM ITR pistons
- Skunk2 valvetrain
- Skunk2 Stage 2 cams
- Skunk2 cam gears
- 345cc Prelude injectors
- DH-R ported B16 intake manifold
- DH-R bored out B16 throttlebody
- DC 1-piece 4-2-1 header
Old Aug 31, 2009 | 07:59 AM
vadimkag's Avatar
Check my video with my stock ls vtec. You'll love the turbo on it.
Old Aug 31, 2009 | 08:36 AM
HiProfile's Avatar
You will be severely disappointed with an NA LS/VTEC vs a boosted stock D16A6, let alone a boosted piston/rod LS/VTEC. The main issue with that block is it has the high compression cast-aluminum pistons. Very good tuning can reduce the risk, but only for so long. Then you'll need new pistons, and possibly a new head & turbo if it's a very bad blowup.
Here is a NA built LS/VTEC:
http://forums.evans-tuning.com/viewt...hp?f=39&t=3030
Here are some turbocharged LS/VTEC's (both near 9:1):
http://forums.evans-tuning.com/viewt...hp?f=38&t=3878
http://forums.evans-tuning.com/viewt...hp?f=38&t=5377
Old Aug 31, 2009 | 09:59 AM
imationdawg's Avatar
get oem bumper and fenders imo. would solve your problem and would look 100x better
Old Aug 31, 2009 | 10:44 PM
vw eater's Avatar
i dont care what you think would look better iam asking about running this motor with these spec's with a turbo set up
re rex
Nov 22, 2013 07:04 PM
ef8_eg6
Jul 25, 2008 04:33 PM
josh0407
Apr 25, 2007 01:37 PM
