Mounting catch cans?
Old Jun 11, 2009 | 10:03 PM
Silvertc's Avatar
Default Mounting catch cans?
I'm running two catch cans on my boosted B16, one with lines that run to the block, and the other that runs to the valve cover. Now what i want to know is this, someone told me that i have to mount that catch cans at least where its level to the motor?
Old Jun 13, 2009 | 06:08 AM
Silvertc's Avatar
Default Re: Mounting catch cans?
anyone?
Old Jun 13, 2009 | 10:28 AM
damndan23's Avatar
NOT TRU
Old Jun 13, 2009 | 12:18 PM
[Ennis_D]'s Avatar
Wow, way to help the man out and give proof of your point. What makes it an even more valid statement is the fact that you used 1. all caps 2. "TRU" instead of "true". Seems very educated...
To the OP, I have heard both sides of the coin. I have never seen any proof of which one is correct. I would think mount it level, or above drain points even if a slight bit, to play it safe. Hopefully someone can step in here and give some findings/thoughts on the subject
Old Jun 13, 2009 | 05:22 PM
Silvertc's Avatar
thanks man. I appreciate it.
Old Jun 14, 2009 | 05:55 AM
b20beast83's Avatar
Gravity drains it i think
i mounted mine on the apron
Old Jun 14, 2009 | 03:04 PM
accord_raffi's Avatar
I've heard keep it level, too. I haven't seen any proof to back it up yet either so I'm in for results.
Old Jun 14, 2009 | 04:30 PM
88ED8's Avatar
If you have a drain from the catch tank back to the block then the catch tank must be slightly above or level to the port or fitting on the engine in order for the fluid to flow back into the motor... If your catch tank does not drain back to the engine the you can mount the catch tank anywere you want.
Old Jun 14, 2009 | 04:47 PM
not to be off topic but does anyone every use a vacuum source to help pull the vapors? like, does anyone have a line tapped into the preturbo intake pipe so that vacuum assists the pulling of the vapors/pressure?
95gsrhead
Nov 8, 2006 02:01 PM
Crimson_Tide
17
Feb 22, 2006 01:24 PM
al3e
Jun 5, 2005 09:13 AM
2slowCivic
Audio / Security / Video
Sep 30, 2003 03:08 PM
trbob16a
Sep 13, 2002 02:23 PM
