motor mount issue...avid
do you guys think i will be safe mixing motor mounts...here the deal
rear avid mount
stock transmission mount and stock timing belt side mount both with prothane inserts...(will i be ok with this setup)
only reason i am keeping the avids in because i don't have to run the lower mounts...its too much of hassle to put those mounts back in
right now i have alot of vibration because the tranny side avid mount is sinking insides and the mount actually has contact with the chassis?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM_Risa »</TD></TR><TR><TD CLASS="quote">
rear avid mount
right now i have alot of vibration because the tranny side avid mount is sinking insides and the mount actually has contact with the chassis?</TD></TR></TABLE>
put the stock mount back on the transmission side man....
you should run the lower torque mounts with inserts....I wouldnt leave them off
rear avid mount
Lol... I had the same problem with the tranny side mount. It pinches there. I ran it like that for a couple months and never had a problem honestly. It does cause the car to vibrate a lot more. Once I swapped my motor again I put a stock mount in though.
i already ordered some innovatives mount already...there in the mail...thanks for all the replies
i am just planning to run the stock tranny side and stock timing belt side with prothane inserts...will it be safe i don't really want to break an axle or anything
crxY-49
12
May 8, 2003 11:04 PM
