Most Power on B16A cams
Old Feb 5, 2009 | 03:31 AM
extremeracer's Avatar
Icon7 Most Power on B16A cams
Hi
Please post some setups using B16A cams and what's the most power that has been made on B16A cams
Old Feb 5, 2009 | 07:56 AM
nsxmatt's Avatar
Default Re: Most Power on B16A cams
Why?
Old Feb 5, 2009 | 07:58 AM
boostedcivicsir's Avatar
Mr. Badwrench
are you looking for something specific? og threads are og, and new post yout "this setup" dont fly. so if you are looking for something specific, please ask it.
Old Feb 5, 2009 | 10:27 AM
Ok sorry -
What is the most power that has been made on built turbocharged B series engines using the B16 head and B16A cams , either straight B16A's or LS/Vtec or B20Vtec setups.
Im looking to build a sleeved fully built 81.5mm LS/Vtec with a cleaned up B16A head, Crower valvesprings, Ferrea 0.5mm over valves and a 62mm Borg Warner Hybrid turbo running 22 psi
I'd like to know how far other owners/tuners have gone on B16 cams (horsepower wise) as opposed to using GSR/CTR/ITR/PRO1/Tuner2 cams
Optimistically I'd like to make 500whp with the above running no more than 22 psi - is this possible with the B16 cams ??
Hope this clears it up
Old Feb 5, 2009 | 10:33 AM
TheShodan's Avatar
Moderator
yes. that is easily possible. Even moreso w/ GS-R cams. There's really no need to go any higher for that power goal. You'll like that S362. Don't worry about whp psi it makes it in, especially if you have a 3bar map sensor. Thats up to the tune.
Old Feb 6, 2009 | 10:50 AM
bigb16's Avatar
I'm still using stock B16a2 cams/stock B16a2 head. I made 375whp 270tq at 20psi 93 octane with a Peakboost turbo kit (Garrett t3/t4 57trim .63a/r) so my turbo is much smaller than yours. Oh and it was with a 2.5" catback. I'm getting a 3" electronic cutout, so I should see well over 400whp with this setup.
Old Feb 6, 2009 | 10:53 AM
Turbo-charged's Avatar
808whp but had to strugggggggle to get there. it was pretty stupid actually
Old Feb 6, 2009 | 11:13 AM
narfdanarf's Avatar
lol
Old Feb 6, 2009 | 12:35 PM
turbociv910's Avatar
the the cheap cost of gsr's your much better off.
Old Feb 8, 2009 | 03:20 AM
Unfortunatly here in South Africa we never got any other B series vtec engines other than the B16A - so that makes finding GSR cams a bit tricky coz Id need to import a set from the US
Where is a good place to find ITR or GSR (used) cams ???
christ0pher
Jul 17, 2007 12:09 PM
TurboJesse
Nov 10, 2003 05:54 PM
Cory man
Feb 25, 2002 05:04 PM
1.8EG-T
Jul 31, 2001 07:40 PM
