Mods Under $300??
Old Dec 4, 2002 | 11:17 PM
TurBoXBirD16's Avatar
Default Mods Under $300??
Hey guys,
I got some extra money to spend.. what should i spend them on??
it's a sohc with stock internals with greddy kit, ICed, Greddy Evo Exhaust with Greddy downpipe, using the Blue Box, autometer a/f and boost gauge.. ACT clutch action 6 puck disk
I am thinking either upgrading to DSM 450 injectors with SMC OR some LS rods and fuel pump??
Give me some clue guys !!!
Old Dec 4, 2002 | 11:22 PM
InfamousRS's Avatar
Default Re: Mods Under $300?? (TurBoXBirD16)
Thats the first thing I though of.
Old Dec 4, 2002 | 11:25 PM
Default Re: Mods Under $300?? (InfamousRS)
but when it comes to tuning, would my autometer a/f gauge be enough??
i also have the apexi TT that shows a/f numbers and O2 voltage... but it's not the same as the autometer a/f...
when i boost, the apexi TT sometimes shows 14.7, sometimes 14.5....
Old Dec 4, 2002 | 11:40 PM
MotorMatrix.com's Avatar
I am a bad person
Used NOS kit!!
Old Dec 5, 2002 | 06:13 AM
Default Re: Mods Under $300?? (MatrixAutoSalon)
i don't want to blow my engine
anybody else want to give me some more ideas??
Old Dec 5, 2002 | 08:47 AM
tygsr's Avatar
THose gauges are not very accurate. DO you have an EGT gauge??
Old Dec 5, 2002 | 08:50 AM
willyboyK20's Avatar
I would get the smc and 450cc's and head to a dyno.
Old Dec 5, 2002 | 10:48 AM
Default Re: Mods Under $300?? (willyboyD16)
i don't have a EGT gauge..
should i get a EGT gauge first then SMC/ 450cc??
thanks
Old Dec 5, 2002 | 11:03 AM
mos's Avatar
mos
Old Dec 5, 2002 | 12:01 PM
CzanSOHC's Avatar
Default Re: Mods Under $300?? (mos)
smc and 450cc.
Old Dec 5, 2002 | 12:30 PM
Default Re: Mods Under $300?? (CzanSOHC)
should i get a EGT gauge first??
or just go with SMC and 450??
thanks guys
Old Dec 6, 2002 | 10:52 AM
anybody want to answer my question?
Old Dec 6, 2002 | 11:22 AM
AB16A2T's Avatar
I would get the 450s and SMC, SMC is really really easy to tune.
Old Dec 6, 2002 | 11:30 AM
GraphiteAccord's Avatar
Default Re: Mods Under $300?? (AresB18C1Turbo)
its echoing, 450's and smc.
Old Dec 6, 2002 | 01:33 PM
bruthaboost's Avatar
upgrade rear sway bar. The R sway bar was the best mod I did for under 200.00
Old Dec 6, 2002 | 01:46 PM
JM Performance's Avatar
Default Re: Mods Under $300?? (bruthaboost)
nx n-tercooler?
Old Dec 6, 2002 | 01:51 PM
Default Re: Mods Under $300?? (00SilverLS)
alright
that means i should trust my a/f ratio gauge (autometer)
thanks guys
Old Dec 6, 2002 | 02:11 PM
T-sohctec's Avatar
NO, NO YOU SHOULD NOT "TRUST" YOUR AUTO METER GAUGE!
You "could" trust an EGT gauge but personally I would only "trust" a wide band and a dyno. but that's off this subject. now back to topic.
for $300 I would get 450's ($75 + 25 for resistor pack) a pump ($100) & SMC ($100).
As if 10 other people haven't already suggested this!!!
Happy Shopping
Old Dec 6, 2002 | 03:47 PM
Default Re: Mods Under $300?? (T-sohctec)
i thought i don't need a fuel pump with the SMC...
tyhanks guys
Old Dec 7, 2002 | 11:49 PM
sorry guys, I have to bring this to the top again.
So I decided to go with DSM injectors with SMC
Now once I install the injectors and SMC, what do I do about tuning?? I don't have a dyno near by nor I have money for it yet.
You guys asked me not to trust my a/f ratio gauge nor my apexi TT's o2 voltage.
Then HOW do I know if my car is running rich when boosting??
Thanks
Old Dec 8, 2002 | 12:23 AM
PureTeg420's Avatar
one way to check is have someone follow you when you boost and find out if they can see any dark smoke come out. Another way would be to check your plugs. usually the darker the plug, the richer you are running. Those are just two cases which I personally found to be evident in my setup.
Old Dec 8, 2002 | 01:51 AM
Dramier's Avatar
Default Re: Mods Under $300?? (PureTeg420)
Well, if you run TOO lean you'll hear the ping of detonation start knocking on your door. And believe me, that is one HELL of a heart-stopping sound. Imagine getting your jimmy hat wet and getting kicked in the ***** mid-stroke. Yeah, that bad.
Do some test runs, listen for pinging, keep an eye on your A/F for huge dips, and just pull and check a plug here and there. Mine tends to lean out for a second on a power shift into 2nd and 3rd, and ejects a small puff of black smoke. If you ever watch videos of Supra's, you'll see exactly what that looks like since nearly all of them do it sooner or later.
EGJDM
Jan 14, 2004 03:13 PM
Tru Dynamix
Oct 12, 2002 10:33 PM
morepoop4u
May 19, 2002 04:05 PM
DamonBoost
Oct 5, 2001 02:43 PM
TypeC
Aug 29, 2001 07:23 AM
