mixing your own E85?
Old Oct 15, 2013 | 01:02 PM
$MIKE$'s Avatar
Default mixing your own E85?
Ive heard alot about the inconsistencies in the e85 on the pump i know that VP and Sunoco make E85 that is pure and consistent. however it is expensive and hard to get. i heard a suggestion that i mix my own E85 using alcohol and adding 15% gasoline, has anyone tried this before or is it not what im looking for? thanks
Old Oct 15, 2013 | 01:08 PM
Turbo-LS's Avatar
Default Re: mixing your own E85?
It's not as simple as that. You have ton use a binding agent. Not sure what though
Old Oct 15, 2013 | 01:16 PM
$MIKE$'s Avatar
yea i figured it. thanks
Old Oct 15, 2013 | 01:17 PM
$MIKE$'s Avatar
what about "spiking" my pump e85 with alcohol? i imagine the same its not that simple right
Old Oct 15, 2013 | 01:23 PM
Turbo-LS's Avatar
You could just get a tester and be sure you have a good blend or get a flex fuel sensor
Old Oct 15, 2013 | 02:30 PM
$MIKE$'s Avatar
Yea I got one it's in the way the vp guy wants 750 for. 54 gal drum of vp c85 lol that's 14.50$ a gal !!
Old Oct 15, 2013 | 03:55 PM
Freemananana's Avatar
Wow. Pass. I'll stick to 93 Octane haha.
Old Oct 15, 2013 | 04:02 PM
portenio78's Avatar
You also have to apply for a permit. and jump through legal hoops if you want to "make" it yourself. Also your home insurance will not like any of this going on in your garage. I looked into this 2 years ago, and said screw it and just bought a tester.
Old Oct 15, 2013 | 04:08 PM
Tippyman's Avatar
Make moonshine. E100!
Old Oct 15, 2013 | 05:46 PM
$MIKE$'s Avatar
I thinking of trying a couple of the 5 gal Sunoco pales of e85R. maybe I can mix it with my pump e85 and come up with somting that will be suitable!!
Old Oct 15, 2013 | 05:47 PM
$MIKE$'s Avatar
you ran pump on your del sol? any problems with it?
Old Oct 15, 2013 | 07:18 PM
Turbo-LS's Avatar
No do not mix it with pump E85 its same concept.
You can get barrels of Ignite shipped for less than the VP fuel. You can also get E98 shipped. there are multiple places that ship it.
Ignite is 230 for E98 plus shipping. One barrel is 225 shipping and the more you order the less per barrel the shipping cost. Ignite 114 is 270 plus shipping. I also got a quote from another company for E98 shippd was 425. All 55 gallon drums
Old Oct 15, 2013 | 07:30 PM
a1320honda's Avatar
If you wouldnt mind sharing where you got your quotes from....
Ive been looking locally and within the state for E85 and E98 shipped and so far havent turned up anything under $830 for VP E85 55 54 gallon drum shipped.
Old Oct 15, 2013 | 07:48 PM
Turbo-LS's Avatar
Call Ignite Fuel @ 317-407-8944
Also just search for E85 online you'll find a forum for it and has a list for all the dealers and they will all mainly ship
Old Oct 16, 2013 | 02:21 AM
$MIKE$'s Avatar
Thanks for the info.
Old Oct 16, 2013 | 02:58 AM
$MIKE$'s Avatar
http://igniteracingfuel.com/E-85.html
Old Oct 16, 2013 | 05:58 AM
portenio78's Avatar
I used to run the same tune for stuff out of the pump that tested at 82 percent and 70 percent. Never had a problem. Fuel changes were extremely minimal on the tune.
Old Oct 16, 2013 | 10:32 AM
$MIKE$'s Avatar
Good info. yea i called the guys at ignite 450 isnt bad shipped, for a 55 gal drum, wish i lived closer i would get some of the 5 gal pales, but if the fuel changes will stay minial and A/F dont drastically change i will be ok. thanks for everyones help!
Old Oct 16, 2013 | 11:01 AM
turbohatch96y7's Avatar
Get an aem v2 with a flex fuel sensor and don't worry about the blends.
Its blends your maps as it detects e85 content.
Old Oct 16, 2013 | 12:18 PM
$MIKE$'s Avatar
Nice didn't know that!
Old Oct 16, 2013 | 02:41 PM
That just came out in the new aem update in august.
I'm going to set it up in a couple weeks. Its very simple to do.
Old Oct 16, 2013 | 06:16 PM
wantboost's Avatar
Who is Mr Robot?
yea all you need is a flex fuel sensor and a 93 map and an e85 map, run the wire from the sensor that outputs voltage based on ethanol percentage and the ecu will do the rest
yay for technology
Old Oct 17, 2013 | 04:25 AM
D-Rob's Avatar
I've run the same tune all year long, with ethanol content ranging from 88% the whole way down to 72% here in PA with no changes at the 600hp level on my personal stock engine K20. It richens up a hair, but whatever. Perhaps I don't tune to the ragged edge.
Old Oct 17, 2013 | 04:03 PM
$MIKE$'s Avatar
Good info I have just switched to e85 and was concered with what I was hearing but both you and another member have told me the same thing both on 500+ whp set ups as mine is as well. thanks all for all the info.
Old Oct 17, 2013 | 10:14 PM
wantboost's Avatar
Who is Mr Robot?
You would think they would have a consistent blend from the refinery and whatever they load on the tanker should be the same... it's more than likely that fresh e85 being pumped into a holding tank with older e85 (possibly even from a different supplier) that could cause the purity issues
