Missing part of Tial WG
Old Jun 27, 2002 | 11:39 AM
Tired's Avatar
Default Missing part of Tial WG
I bought my tial 35mm wastegate used and never had the top port:
anyone know where I can get this piece seperately or a workaround?
Never needed this port before but just got my hbc in the mail and its waiting to be installed
Old Jun 27, 2002 | 11:46 AM
93LSivic's Avatar
Default Re: Missing part of Tial WG (Tired)
Just get an Earls barbed fitting. Most people have to replace that Tial fitting anyways cause it usually hits the hood--the earls' is lower profile.
Old Jun 27, 2002 | 11:57 AM
Tired's Avatar
Default Re: Missing part of Tial WG (93LSivic)
What size would the male end (into top of wg) need to be?
Anyone who has replaced this piece before, do you have a part# ?
Old Jun 27, 2002 | 11:59 AM
93LSivic's Avatar
I forget off hand. Maybe if you IM Dustin and ask him nicely he will give you a part number.
Old Jun 27, 2002 | 12:44 PM
jeremyG2teg's Avatar
I believe its 1/8 npt
earls part # 984204
anplumbing's price 16.20
Old Jun 27, 2002 | 12:51 PM
Etylorcen's Avatar
Default Re: Missing part of Tial WG (jeremyG2teg)
You only need that if you run a ebc.
Old Jun 27, 2002 | 01:13 PM
TheShocker's Avatar
Default Re: Missing part of Tial WG (Etylorcen)
You can just leave it off and you'll be fine. usually you leave that vented to the atmosphere anyway.
Old Jun 27, 2002 | 01:50 PM
niedejb's Avatar
Default Re: Missing part of Tial WG (Matthew)
You dont need it. I have that same wg and a Profec B. I only use the side port which is connected to the out of the boost controller.
Old Jun 27, 2002 | 02:04 PM
Ri5e's Avatar
Default Re: Missing part of Tial WG (niedejb)
Uhh...are you sure your connecting it right? The "OUT" on the stepper motor connects to the top of the wastegate on my Tial.
Old Jun 27, 2002 | 02:05 PM
niedejb's Avatar
Default Re: Missing part of Tial WG (BG Boost)
Yep, got her boosting @ 10 for low and 13 for high. Works like a charm.
Old Jun 27, 2002 | 02:06 PM
sgT's Avatar
sgT
You can hook up a BC either of the two ways.
Either:
Boost -> controller -> side port
or
Boost + side port -> controller -> top port
Old Jun 27, 2002 | 02:33 PM
niedejb's Avatar
Default Re: Missing part of Tial WG (sgT)
Either:
or
Wont the last scenario let boost get to the wastegate before the controller opens? With the controller shut, <desired boost level, the boost would go straight to the wg and start opening it. Help me understand.
Old Jun 27, 2002 | 02:49 PM
Tired's Avatar
thanks for all the replies... just to get it all straight..
i can leave the top port open to atmosphere and use the side port for an mbc.
top port is for an ebc such as the profecb/blitz/etc.
Old Jun 27, 2002 | 03:08 PM
89civic1.8T's Avatar
I always though that the Top port was for a boost controller. I thouhg that the boost controller would let boost go to the top port causeing the pressure on both sides of the diaphrame to have equall pressure and then once you reach the preset boost level it cuts boost to the top port? Am I wrong? My Blitz SPBC has two setting on the brain for AC/WG. I though WG mode would make it work like I metioned above and AC mode just cut the boost that the wastegate saw. I never got the instructions with mine becasue it was bought used.
Old Jun 27, 2002 | 03:09 PM
GSRwBOOST's Avatar
yea.. thats hooked up wrong....
the boost cotnroller pushes down on teh top of the spring to keep it closed until full boost is reached.....
Old Jun 27, 2002 | 03:13 PM
Arturbo's Avatar
Better than steak
25 Year Member
Default Re: Missing part of Tial WG (89civic1.8T)
You dont need the top port. Im using the profec A with only the side port of the tial.
art
Old Jun 27, 2002 | 03:24 PM
sgT's Avatar
sgT
The boost controller regulates boost to the top port which will balance the boost
trying to open the WG. When boost reaches the specified amount, the controller
shuts the flow to the top port allowing the WG to open.
Old Jun 27, 2002 | 04:17 PM
niedejb's Avatar
Default Re: Missing part of Tial WG (Arturbo)
art
Old Jun 27, 2002 | 04:38 PM
TurboCivicSi's Avatar
Default Re: Missing part of Tial WG (TheShocker)
The top port of the waistegate is very important if you plan on controlling boost beyond the preset spring weight.
Especially if you are using a profic or AVC-R, this connection is very inperative!!
If you attempt to controll a poppet style waistgate like a swinggate with a normally closed connection attached to the bottom of the diphram, you will see major spiking. Attaching an open connection to the bottom, and then a Nomally open connection to the top port, you will see immidiant control of the waiste gasses..
See ya.
-Jason
Old Jun 27, 2002 | 04:49 PM
highmilehatch's Avatar
Default Re: Missing part of Tial WG (TurboCivicSi)
Now I'm confused. I thought you needed the top port with an ebc. Although I do remember my freind hooking up my profec b and tial using only the side port, and the wastegate did open when it was supposed to. However, the switches on the back were still set for an internal wastegate. Wierd.
Fastjato33
Jul 18, 2009 10:36 AM
rioninja
Aug 30, 2005 09:40 PM
green91
Jul 16, 2004 06:00 PM
queez
Dec 11, 2003 08:24 PM
B18C4-T
Jun 29, 2002 01:14 PM
