Misfires
Old Feb 9, 2005 | 03:29 PM
Ls InTeGrA RaCeR's Avatar
Default Misfires
Ok I've replaced my spark plugs, wires, dist. cap, and rotor 3 times and I'm still getting the stupid Misfire. I can hear it sitting at an idle (car is even idling weird). It throws the check engine light occassionally but not always. The only thing I've done to my car in the last 3 weeks is adjust the valves. Is this misfire caused by a bad valve adjustment? Also, the car is running rich or lean (the car stutters sometimes when I step on the gas). Any ideas?
Old Feb 9, 2005 | 03:54 PM
tremor86's Avatar
Default Re: Misfires (Ls InTeGrA RaCeR)
A misfire could definately be caused by a bad valve adjustment. I am having a misfire problem right now too because my ignition coil and igniter are arcing together intermittently and it always happens between 2-3k and it seems like it almosts wants to die. How many miles are on your car? Coils are known to go bad in hondas and cause misfire problems. I would check your valve specs first... then go to the coil then the igniter.
Old Feb 9, 2005 | 04:10 PM
Default Re: Misfires (tremor86)
The Car itself has 67,243 miles on it (2,000 after a rebuild and 500 miles after valve adjustment).
Old Feb 9, 2005 | 05:11 PM
Other than the valves, what else could it be (incase the valves aren't the source of the problem)?
Old Feb 9, 2005 | 06:35 PM
Old Feb 9, 2005 | 08:02 PM
mtber's Avatar
If your valve clearance job was done poorly your motor will fall on its face and sound like its running on a dead cylinder or two....
Old Feb 10, 2005 | 02:34 AM
Default Re: Misfires (mtber)
yeah but other than the little stutter it runs strong.
Old Feb 10, 2005 | 01:21 PM
no one else?
Old Feb 10, 2005 | 04:05 PM
damn...no one else has a clue?
Old Feb 10, 2005 | 04:33 PM
foumer's Avatar
W95 gives me a hard-on
have you check what the check engine code is? I am pretty sure is code number 9. I am have somewhat the same problem. I throw code 9 sometimes and my car misfires alot, which means one of the distributor sensor is done. What rotor did you get? aftermarket? Be careful with the one you choose, most of the aftermarket ones are not insulated and cause arcking in the distributor and burn your sensors. Also recheck you gaps on the cams.
Peace
Old Feb 10, 2005 | 05:04 PM
Default Re: Misfires (foumer)
I'm getting codes 72 and 74 My car was acting strange before I changed out the plugs/wires/rotor/cap so I thought that was the problem.....wrong. Still have the problem after changing everything 3 times.
chsmurphy
Honda CR-V & Element
35
Dec 20, 2021 12:25 PM
Fitfits
Honda Fit
Aug 13, 2016 09:25 AM
Mikebdelsol93
21
Jun 15, 2015 06:28 PM
greenskittle
23
Jul 26, 2012 01:39 AM
97BB6Type-SH
Feb 2, 2008 10:10 AM
